OBD1 or OBD2?
Old Jan 12, 2004 | 09:06 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
OBD1 or OBD2?
The computer for my LT1 is from a '96, so is the engine. I'm in the process of planning my LT1 buildup. Would it be worth it to leave it OBD2? That way I could hook up the tech 2 to it.....or would OBD1 be a much better way to go?
Old Jan 12, 2004 | 10:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well if you keep it stock OBDII is easier to diagnose and won't cause any problems. If you go with OBDI it is more responsive to mods and only requires 2 O2 sensors. However you can delete the rear O2's with OBDII. There are a few other things but I can't remember off hand. Generally OBDI is more preferable.
Old Jan 12, 2004 | 10:30 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
OBD I, get yourself LT1 edit and call it a day.
Old Jan 12, 2004 | 10:46 PM
TexasLT1's Avatar
Car: '92 RS
another vote for OBD1
Old Jan 13, 2004 | 06:05 AM
ghostrider's Avatar
Car: 1987 Firebird Formula
Engine: a less than exciting LG4
Is the Tech 2 the GM diagnostics and programming tool? If so, and if you have access to one is OBD I still preferred? I thought you could make the same modes in OBD II as OBD I it was just more difficult unless you had something like the Tech 2. Is this true or not?
Old Jan 13, 2004 | 06:14 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you can still use the TECH 2 with OBD 1.....................
OBD 2 is alot more sensitive, but might be worth it because it will point closer to where a problem is
depends on how much you are modding the engine
junior419
Apr 7, 2025 11:35 AM
Z28L9891
Jan 24, 2006 07:41 PM
91rs5.0
Apr 5, 2005 08:24 AM
sinner
Jul 17, 2003 11:42 PM
