obd1 or obd2?
Old Apr 5, 2005 | 06:45 AM
91rs5.0's Avatar
Car: 91 RS (Black, T-top)
Engine: 5.0
Transmission: 5-speed
obd1 or obd2?
i have a 95 lt1 that I need a harness and computer for. which computer should i get, obd1 or obd2? will obd2 work with lt1 edit? i've seen some people swap obd2 for obd1, why would someone want to do this? thanks.
Old Apr 5, 2005 | 08:01 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The 95 LT1 I have had the OBD2 connector, but is an OBD1 computer. The computers and harness that are OBD2 have a crank position sensor if I am not mistaken which started in 96 that my 95 does not have.
Old Apr 5, 2005 | 08:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are correct. ODB1 is the prefered set-up for Gen II motors. OBDII can be used but I hear OBDI is more tollerable and easier to tune when radical combos are put together.
junior419
Apr 7, 2025 11:35 AM
Z28L9891
Jan 24, 2006 07:41 PM
tamatt27
Jan 13, 2004 06:14 AM
sinner
Jul 17, 2003 11:42 PM
