Carbed 305
Old Jan 17, 2004 | 12:46 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
Carbed 305
140 hp and 240 tq stock, what would the numbers be with hedman shorty headers and a perfromer intake manilfod. Also a edlebrock 600 carb. I'm guessing 165hp but not sure on the torque?
Old Jan 17, 2004 | 03:17 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Headers/intake/carb with no other mods should get you probably 165 HP and 265 lbs/ft. maybe more.
Old Jan 17, 2004 | 05:14 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Likely a lot more...
I'm running an 84 LG4 (150hp stock) with Hedman shorties, their Y-pipe; Dynomax catback, stock cast-iron intake and the stock non-CC Q-jet with DR secondary rods and an N hanger. It has a 'small' cam in it, .420" lift intake and exhaust. Engine has just under 250k miles - the heads have never been off it - and it runs around 98.5 in the ¼ mile. Weighing about 3400lbs, that calculates to approximately 275 HP.
I wouldn't be too surprised to see near 200 HP with your additions.
Pete
Old Jan 17, 2004 | 05:47 PM
You have to be careful about getting horsepower from your 1/4 time and MPH. The formulas don't take into account rear gear ratio, trans type, 60ft time, ect. Keep in mind that I can go from 2.73s to 3.73s and run a full second quicker in the quarter. If I did calculations before and after it would say I gained 100 horsepower! I didn't, I just used the engine's power more efficiently.
Don't get me wrong, this is a great set of upgrades for your car, and will make it a lot more fun to drive, but don't expect miracles without doing head work and a bigger cam. All of which needs to be matched to the right compression ratio.
Old Jan 17, 2004 | 10:26 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hp doesnt really matter. Its the whole car combo that gets down the track. With a properly tuned 305 you should be able to get into the high 13's low 14's and still be streetable.
pimp2303
Jul 27, 2017 02:03 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
