Motor mounts on a 3.1
Old Jan 19, 2004 | 02:22 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
whats the best way to get the bolts out? ive been trying but cant get a ratchet on the nut on the passnager side mount, and the driver side i dont see the same bolt as the passanger. Help!
Old Jan 19, 2004 | 04:25 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Swival socket and a long extension did the trick for me.. very very easy from there.
Old Jan 20, 2004 | 04:01 PM
Transmission: autos
can i take out the ones that hold the mount to the frame, or should i take out the ones that go though the middle of the mount? Is there only 2 of each mount going into the crossmember? The ones holding it to the crossmember are much easier to get to than the one though the middle, since i cant get to the bolt in the middle on the passanger side
Old Jan 21, 2004 | 06:16 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
dont remember how much bolts, but i will tell ya you need to get them all out and the easiest way i know is to use a swival with a long extensions. I got mine out and back in in about 1/2 hour easily.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
