71 Le Mans
Old Jan 24, 2004 | 12:08 AM
Aqua FBody's Avatar
Car: 95 Contour GL 03 KIA Spectra
Engine: 2.0 Zetec 1.8
Transmission: MTX-75 5spd
71 Le Mans
My buddy is giveing me a running 350 and a turbo 400 trany out of a 71 Le Mans. Is it possible to get that thing to pass the smog test for my 91 3.1 and if so how.
Old Jan 24, 2004 | 07:36 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
I'm pretty sure it's "illegal" (at least in states that do smog testing) to swap an older motor into a newer car.
Old Jan 24, 2004 | 10:32 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Maybe, if you can lean the hell out of it, & slip the attendent a $100, maybe.......
or just wait until after it's tested
if they do a visual test, then you're SOL
Old Jan 24, 2004 | 11:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a Pontiac motor, not a Chevrolet. Absolutely nothing whatsoever about a Pontiac motor will interchange with a Chevrolet, except for a couple of internal distributor parts and maybe the spark plugs and maybe a couple of bolts. The exhaust, motor mounts, and lots of other things are completely different. You will spend more just trying to jam that thing in there even if you got it for free, than you will buying a whole Chevy 350 motor and trans and doing a smooth easy install.
Besides, it's a 350. A Pontiac 350 is to a Pontiac 400 as a Chevrolet 305 is to a Chevrolet 350; same stroke, tiny bore. It's a poor choice for a swap.
If you just really want a Pontiac motor for some reason and you don't care whether you end up with the best possible result as far as it being fast, you just want a Pontiac motor, then it might be worthwhile. If you're looking for best bang for the buck, that isn't it.
Old Jan 26, 2004 | 07:59 PM
Engine: 5.7 / 7.4
he could also go all out ape shyt on it & copy that one Poncho 350 putting out like 600hp or so w/the paxton or ati setup :rockon:
PurelyPMD
May 5, 2016 04:57 PM
Magman
Sep 12, 2015 10:43 PM
