97 Lt1
Old Jan 26, 2004 | 01:20 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
97 Lt1
Hey guys,
I am about to purchase a 97 LT1. I have been doing alot of reading about stuff on the board. I just want to make sure that I got it straight. For a 97 I would just need to have the PCM sent out and have the VATS deleted and I am good to go correct? Or did I screw that up. By the way it is going into an 89 RS. Thanks.
Old Jan 26, 2004 | 04:28 PM
TexasLT1's Avatar
Car: '92 RS
Yup, thats all you need to do. If you wanted to keep VATS, all you would have to do is get a new VATS module and repin the connector for it.
Old Jan 26, 2004 | 05:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are also going to have to run 2 rear o2's past the cat. i would have them deleted when you get the vats taken care of. Oh and have them get rid of that pesky speed limiter if the car was equipt with one.
Old Jan 27, 2004 | 12:30 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Hey guys another question.
This engine originally had an auto trans. I am going to bolt up my T-5. Will my stock flywheel and everything from the 305 bolt right up? Or am I going to have to change anything. Thanks again.
Old Jan 27, 2004 | 06:19 PM
TexasLT1's Avatar
Car: '92 RS
Not at all, just use the 305 flywheel and you'll be good to go. I would highly recommend getting a better clutch though. I've been using a Centerforce Dual Friction for the past 2 years and its been incredible. Oh yeah, and I'm using a T-5 too.
Another thing you will want to do though is when you have your computer programmed, be sure they give you a program from a manual car, you wont throw and trouble codes and it will idle correctly.
Old Jan 27, 2004 | 06:21 PM
lt1g3n's Avatar
Car: 1983 Camaro
Engine: Lt1 (383 project)
i would get the fly wheel for your car the 97... since the starters are different im sure and you'd be using a starter for the 97.. it should still be fine with your trans.. i dont know much about the t5 ;/
Old Jan 27, 2004 | 06:22 PM
lt1g3n's Avatar
Car: 1983 Camaro
ah, i didnt know u could use the same as 305, that's cool , good to know, thanks!
Old Jan 27, 2004 | 10:09 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Thanks guy's. That skinda what I figured but just wanted to make sure before it's all in pieces.
Old Jan 29, 2004 | 08:44 PM
TexasLT1's Avatar
Car: '92 RS
yeah the 305 flywheel is the same size and tooth count as the LT1, so the LT1 starter works fine
Old Feb 1, 2004 | 05:26 PM
STU86ZLT1's Avatar
Car: 1986 Z28
Engine: 1997 LT1
are you going to retain emissions? (egr) if not, have that taken out of the ecm prgram. you will also need egr block off plates. GOOD LUCK WITH YOUR SWAP>:rockon:
Old Feb 1, 2004 | 10:39 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Yeah I am going to have to pass emissions. Thanks though.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
