TPI bolt blocks????
Old Feb 2, 2004 | 08:49 PM
  #51
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Crap, Im an idiot...
posted in the wrong topic, I got the site and cut it, and hit back a bunch of times and thought i stopped on the right post, but didnt..lol
Old Feb 2, 2004 | 09:00 PM
  #52
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
what was that supposed to tell me????
Old Feb 2, 2004 | 09:48 PM
  #53
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Originally posted by snowman89
do you think thats good enough size for what I have, or should I go 2:02/1:60 or will the heads handle that....or 1:94/1:60's
Bigger valves are almost always better. But if you are on a budget you are going to be looking at maching expense+the valves+the rest of the junk to hold them down. Since you are on a budget, take the money you'd be spending on the machining and larger valves and get yourself a dremel if you don't already have one. That way you can port and polish the bejesus out of everything you have, TB, runners, base, heads, everything. That'll actually give you a better increase in power than just upping the valve size. Plus it's one more tool to add to your evergrowing collection
Old Feb 3, 2004 | 12:31 AM
  #54
snowman89's Avatar
Engine: 5.8L 355
OK...well I do have a dremel, and I know if I do the porting I'll wish I had a plug in one. Mine is rechargable!!!! So say I don't do anything, but just put this Forged rod and piston setup 76 with the 89 TPI system, what do you think I will get for power, a guestimate???? I know stock I run between 235-245 right. Do you think 300 is possible???
Now since I will have things to sell, 79 heads, and I have a set of 93 350 Truck heads(ported and polished, 3 angled) I would prolly have the money for some machine work after those are sold. And I could port and polish these heads myself(the 89's). Well since I have 1:94/1:50's, would 2:02/1:60's make a difference, will those valve sizes work with the 89 heads???? I have the money for valves right now, its just the machining I would need....thats just getting the valve seat machined for the larger valves??? Like I said I could port and polish the heads, intake, runners, plenum.....what do you think????
Old Feb 6, 2004 | 09:23 PM
  #55
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
The porting on your tpi intake won't bolt up. The 89 tpi has 8 holes for the intake instead of 12.
Old Feb 7, 2004 | 12:15 AM
  #56
snowman89's Avatar
Engine: 5.8L 355
What do you mean porting, what are you referring too????
Old Feb 7, 2004 | 09:11 PM
  #57
maroguy1's Avatar
The intake ports are different between the older heads and the vortec heads. Hence the intakes are aren't the same.:lala:
Old Feb 7, 2004 | 09:14 PM
  #58
maroguy1's Avatar
Bolt holes!!!
Old Feb 7, 2004 | 09:17 PM
  #59
maroguy1's Avatar
I also have an 85 intake that will bolt up to the old style heads for tpi. I used vortec heads on my 357 and had to go with the newer style. Let me know.
Old Feb 8, 2004 | 03:39 AM
  #60
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Ummmm......... What the heck are you talking about? Do you realize that he is going with the 89 heads?
Old Feb 8, 2004 | 09:02 AM
  #61
85TransAm406's Avatar
Car: 1985 Trans Am
um....no....
The later TPI intakes have 6 holes per side, or a total of 12. The only difference in them is that the center 4 holes have less of an angle to them, more like up and down instead of at a 90* angle to the intake flange.
evilstuie
Jan 9, 2020 08:29 PM
mhatfield 14
Oct 24, 2015 07:48 AM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
