Early 350 Block Differences
Old Feb 4, 2004 | 02:13 AM
CamaroSeeker's Avatar
Car: 89 Honda Crx:(
Engine: Hamster
Transmission: Wheel
Was there any differences from a 1970's 350 truck block and the 1980's camaro block? Would there be any reasons that a 1970's block would be better if i was using aftermarket heads, pistons, ect.?
Old Feb 4, 2004 | 05:23 AM
ede's Avatar
ede
no differances in blocks untill the change to one piece rear main seal and roller cams
Old Feb 4, 2004 | 07:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Actually, there is one other difference to watch out for...
Around 1980, they moved the oil dipstick from the driver's side to the pass side... the oil pans are different, and the LH dipstick will not work with stock exhaust manifolds. Makes a good excuse to get headers, which solve the problem.
Old Feb 4, 2004 | 01:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
-which I believe they changed that in 87?
Old Feb 4, 2004 | 01:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
for cars, yes.
when swapping years, as long as they're all pre 87, the only thing to watch out for between the internally balanced ones is the dipstick location... atleast as far as i recall.. might want to double check the starter mount too...
Old Feb 4, 2004 | 02:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
One piece rear main seal started in 1986 model year.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
