carbed lt1 ??
Old Feb 8, 2004 | 09:39 AM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
carbed lt1 ??
what do you guys use for the opti-spark block off
pictures would be great
thanks
Old Feb 8, 2004 | 12:18 PM
TexasLT1's Avatar
Car: '92 RS
I was under the impression that the intake came with a block-off plug.
Old Feb 8, 2004 | 01:08 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the plate doesnt come with the intake..you have to order it by itself...
http://www.sdpc2000.com/cart.asp?act...d=887&pid=1822
it doesnt show a pic, but the hole slips into the timing cover and it attached with 3 or 4 cover bolts, meaning the timing cover doesnt have to come off...
youll also HAVE to use a 6 3/4'' neutral balanced (SBC) balancer because the LT1 7 1/2'' balancer wont fit under the plate...And since the SBC and LT1 balancer assemblies/serpintine setup has different offsets, you may not be able to run the LT1 brackets or accesseries...on my carbed LT1 i modifed my stock brackets to work so i wouldnt have to do anything as far as the power steering, ALT, AC or anything...
HTH
Rob
Old Feb 8, 2004 | 07:20 PM
gta007's Avatar
thanks for all the great info guys
Old Feb 9, 2004 | 01:25 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Why not save yourself the trouble and just leave an old dead opti in its place, no accessory problems, all is well.
Old Feb 10, 2004 | 07:47 PM
NOMADz28's Avatar
Car: 1995 Camaro Z28
Engine: 400+ HP LT-1
You could remove the timing cover and use a large freeze plug to plug the hole. Thats been my cheapest most effective route
-Shannon
Old Feb 11, 2004 | 04:46 PM
gta007's Avatar
so a 87 and above 350 balancer will work as long as i dont use the lt1 belt set up. i would like to use 88 up serpitine set up.
thanks in advance
Old Dec 15, 2006 | 04:16 PM
darkstar575's Avatar
Car: 1988 iroc z
Engine: 355 l98
Holy cow, thank a bunch. I ran into a big problem when I found out that the 6 3/4 balancer didn't match the lt1 belt system. So...all you have to do is modify the serpentine system a little...was this hard? DId you need any special tools?
Old Dec 15, 2006 | 04:30 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
What about using an underdrive pulley for an LT1. This should be significantly smaller. This way you might be able to use the LT1 accessories.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
L0tuS
Oct 4, 2015 08:07 AM
jerflash
Sep 24, 2015 03:11 PM
mygta87
Sep 14, 2015 10:36 PM
L0tuS
Sep 4, 2015 11:16 PM
