Stroking the LT1, how big can it be done?
Old Feb 11, 2004 | 10:03 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Does the LT1 have the same stroking capabilities as the gen 1 small block chevy? Or could a LT1 be bored and stroked to a larger displacement than a 383?
Old Feb 11, 2004 | 10:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Stroking the LT1, how big can it be done?
They have some specially gond cranks that can turn an LT1 into a 396 or even a 409. The 409 is new to me so I don't know to much about it but I wouldn't go much bigger than a 396. A 383 would be the cheapest. Check out this link. They are leaders in the big inch LT1 market.
http://www.nu-tekmotorsports.com/
Old Feb 11, 2004 | 10:42 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I've heard of as big as 422.
I personally would go 396.
Old Feb 11, 2004 | 10:49 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I agree. Once you get past that there is a lot of material removed to allow for the larger crank clearances. This slightly weakens the block and once you past 396 you are making up to and over 600hp and you can use all the beef you can with the stock block at that point. I have never heard of a 422. Are you sure your not confusing this with the 422 LS1?
Old Feb 11, 2004 | 10:54 PM
jmd's Avatar
jmd
Originally posted by ShiftyCapone
Are you sure
Yes.
It was in an automotive magazine in the last 5 years. The guy was from TX and he had a "mild" and a "wild" engine built; both were for his LT1 powered Impala SS.
Old Feb 11, 2004 | 10:56 PM
jmd's Avatar
jmd
Are you sure
Yes. not sure what magazine it was but the guy had a couple built; both for his LT1 powered Impala SS.
Old Feb 11, 2004 | 11:04 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Wow. That would be really neat. I think I may vagly remember that. He must have went with a 4.060 bore and 4.07" stroke. Was that with a custom ground crank?
Old Feb 11, 2004 | 11:09 PM
jmd's Avatar
jmd
I don't believe that it was an OEM crank.
Old Feb 11, 2004 | 11:11 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Oh yea no doubt. I wonder how much he had to spend to get that thing ground.
Old Feb 11, 2004 | 11:28 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
about twice as much as a 396 crank
Old Feb 12, 2004 | 07:20 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Wow
Old Feb 12, 2004 | 09:51 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
personally, i wouldnt build a 396 or a 409...sure youll get a few more cubes out of it, but what about the incresed side loading on the skirts, or longevity?
when i built my motor i set a 50,000+ mile goal...i want to get atleast 50 grand out of this motor..and i just dont think thats possible or plausible with a 396...id rather build a 383 and have it last 100,000 miles then go for 20 more cubes and have it last less then half as long...
Old Feb 12, 2004 | 04:51 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
4-350-3800-5700-3 350380541SL 350 Main - 3.800" Stroke x 5.700" Length Rod, 2.100" Rod Pins 43.0lbs. $1,076.00
thats about what a top of the line 396 crank would run
heres an ENTRY level 409 crank
4-350-4000-6000-2
New!
350 Main - 4.000" Stroke x 6.000" Length Rod, 2.100" Rod Pins
50-51
$863.00
and heres the prices on OLIVER cranks....
SBC3875CB6LB 3.875 400 2.100 52.2 53.5 52.9 54.2
Price: $2599.00
SBC4000CB6LB 4.000 400 2.100 52.9 53.9 53.6 54.7
Price: $2599.00
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
