3.4 Camaro motor into non-GM?
Old Feb 19, 2004 | 02:16 PM
Samuari3.4's Avatar
Car: 1988 Suzuki Samurai
Engine: 1993 3.4 out of a Camaro
What is the best wiring harness/ECU to use to make a 3.4 run in a non-GM vehichle?
I bought a 3.4/700R4 to swap into my suzuki samurai.
Old Feb 19, 2004 | 03:44 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the only to make this swap fully work, is have all the wiring from the donor car: engine harness, pcm, bcm, keys & keylock cylinder (unless you do the resitor thing). THis will let you have full DIS capability & the added bonus of starting the car & keeping it running. A 12v negative ground helps too
My drivetrain came w/everything but the key, key cylinder, & bcm.
Old Feb 19, 2004 | 05:05 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Contact John at speartech.com He can build you a custom harness.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
slade5612
Aug 11, 2015 07:19 PM
Elliswon
Aug 10, 2015 12:33 PM
92projectcamaro
Aug 6, 2015 01:20 PM
