3.1L to 4.3L
Old Feb 20, 2004 | 03:13 PM
firefrombelow's Avatar
3.1L to 4.3L
Got a '91 Firebird, and want some info on a swap...First, How does the 3.1 and 4.3 compare in block size?? Im assuming that I can use the 700R4 tranny...Are manifolds and injectors interchangable between the two?? What is the power potential of the 3.4??
Thanks for your time...
Old Feb 20, 2004 | 03:39 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
3.1 items such as manifolds etc will not bolt up to a 4.3
The 2.8/3.1/3100/3400 V6's are usually parts interchangeable with each other.
The 4.3 is basically a 5.7 350 with two cylinders whacked off.
700R4 will bolt up to a 4.3 but you might need a different bell housing to make it work.
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
4.3 NA power topped out at 190hp.
Old Feb 20, 2004 | 03:40 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
please specify whether you are talking about the 3.4 or the 4.3. the 3.4 is totally interchangable. the 4.3 is about like putting a 350 in the car....minus two cylinders.
jhawkeye
May 25, 2022 06:33 PM
HoosierinWA
Oct 7, 2015 10:15 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
WIzmo
Aug 30, 2015 02:30 PM
