v-6 motor mounts and v-8
Old Feb 25, 2004 | 09:51 AM
cammy's Avatar
Car: 80's somting Trans AM
Engine: 5.0L H.O.
Axle/Gears: not sure yet
are the v-6 crossmember motor mounts the same as the v-8 or do both the motor mount haf on the motor and the car haf to be changed to fit in properly
also i need to know how to move or where to buy the new brake line sense where the brake like is is whre the mounts has to be moved to i do beleave
Old Feb 25, 2004 | 03:17 PM
87T-TopBird's Avatar
Car: '87 Firebird
yes, the v6 mounts are different than the v8 ones on both the frame and motor. On the frame, the v8 mounts are bigger and they mount on the frontmost part of the crossmember. On the motor, the mounts are wider. The frame mounts can be got at any auto parts store for very cheap, but i don't know where you can get the motor mounting ones
Old Feb 25, 2004 | 05:10 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Junkyard or dealership has the clamshells (mounts that sit on the engine), just check the junkyards, they don't even have to come from a camaro I believe the silverados used the same mounts, not sure what year (I got mine from a silverado engine). Dealership wants 45 bucks for one side. thats 90 bucks, the dealer calls them engine braces I believe. They bend you over. Got mine at the junkyard for 15 bucks for both.
Old Feb 25, 2004 | 11:55 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
All I did for the brake line when I did the V6-V8 swap, was to remove the clips holding it to the crossmember, and carefully moved it back to clear the V8 mounts. Just be sure not to pinch it when you are setting the engine in place.
I *think* I left one clip in the middle as it was.
Pete
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
