LT1 Swap but can i keep 3d gen acc?
Car: 89 GTA
Engine: 350 LT1
I am swapping in a 96LT1 taking out 89 305tpi.. my accessories are perfect.. and i don't have any 4th gen accessories.. Is there anyone who has done a swap using 3rd gen accessories?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check out the various LT1 swappers giudes that are floating around here on this forum. It goes into great detail on what you have to do. The vette accesories are the way to go but you can use the f-body ones if you modify the frame rails a bit.
Car: 89 GTA
Engine: 350 LT1
i guess i have to look a bit harder.. I found that vette stuff was easier.. didn't see anything about using 3rd gen... my bad.. will look harder..
Car: '90 RS
Engine: 377 LSX
Originally posted by TexasLT1
He wants to keep his 3rd gen accs. I am working on including a section about doing that for my swap guide, but its going to be some time before I can get it up.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
your gonna give me props for that right
Car: '90 RS
Engine: 377 LSX
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Yeah I am having the same dilema. I am putting an LT1 in my Camaro. It originally has the WC T-5 but It will need a rebuild anyway. I cant decide if a rebuild will be a waste of money. Basically I dont want to pay for a rebuild and then have it blow up on me. By rebuild I mean Synchros and maybe bearings.
If you're putting a stock LT1 in, you can keep the T-5, just be sure to get all new synchros and bearings. Mine has held up great behind an Hotcammed LT4, so you should have no problems.
Oh yeah, I think you meant for this to be in another post
Engine: CARBED LT4
Transmission: MK6
You'll be giving him props after he gets his site done and he schools all of us how to do it.
i was just makin a point that ive already done it...i used my 3rd gen brackets and accesseries on my LT1 swap...
the LT1 balancer hub assembly sits an inch farther out then the 3rd gen balancer...so in order to use the 3rd gen brackets on an opti fired LT1 youd have to make spacers of some sort that goes bewtween the bracket and the head to bring out the brackets...
on a carbed or 730 fired LT1 the alignment of the backets is perfect...
either way, ive modified my brackets to work....and they work like factory...so im good with knowing that i was first one to do it...so thats enough "props" for me....
TEXAS....by no means and i downing anything that youve done or doing....hell i decided on doing an LT1 swap after reading YOUR guide....im just tryin to lend in my experiance in this matter, which is the point of you guide correct?....so if noone wants to use it then thats fine...i feel damn good knowing that people said it couldnt be done and i did it and made it work...thats good enough for me
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I dont see it working very well if that ford t stat housing you used is any thicker than the stock LT1 housing since its already pretty damn close to the bottom of the TB
Car: '90 RS
Engine: 377 LSX
Engine: CARBED LT4
Transmission: MK6
heres a pic of a LT1 housing....notice how it comes out, the SBF housingn come out but it comes up aswell...maybe at a 45 degree angle..itll be maybe a 1/4-3/8 taller
Not a problem shifty....
Texas..when its gets a little warmer ill take some pics of the brackets and the SBF housing
Car: 93 240SX
Engine: LQ9
The picture you posted, you must be looking at the drivers side water outlet thinking thats the tstat housing, its the one sitting higher up on the pass side in the pic, already awfully close to the LT1 body, moving up another 1" your already blocking off a duct to the throttle body.
But you can see the Tstat housing just under the intake duct and it looks fine. Most people block off the throttle body coolant passages anyway.
F-crazy, what did you use between the upper air filter housing and the MAF?
88SS6SPEED
Nov 11, 2015 07:05 AM
New2Chevy
Sep 28, 2015 12:35 AM
