Motor mounts?
Old Feb 25, 2004 | 09:10 PM
g_ride's Avatar
Car: modified 83 berlinetta
Transmission: TH350
Motor mounts?
When we swapped my engine into my car (V8 into a V6 car berlinetta.) it appeared there was a set of bolt holes for mounts placed more towards the front of the car, we used the mounts from an old suburban... anyways long storey short, I can't even bolt the hood back on the car, and Im beginning to suspect that this wasn't the correct way to put a V8 into the car.
Which makes me think that when I pull the motor again I should do something about this, so: what exactly do I need to do?
Thanks a lot for any help.
Old Feb 26, 2004 | 10:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I doubt that's the problem.
What is the hood hitting? What intake manifold/carb/air cleaner are you using?
Old Feb 28, 2004 | 01:11 PM
g_ride's Avatar
Transmission: TH350
just an edlelbrock rpm (approx the same hieght as stock) and the stock carb. (and by stock I mean stock for the 350 thats in the car, being out of a 1983 3/4 truck... with 194 heads.)
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
