Another 305tpi to 350 tpi question computer related
Old Feb 27, 2004 | 05:53 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i got this gta with the tpi 305 and i have a 350 long block. i was just going to pull the engine and use the 305 tpi setup on the 350 and stuff it back in. my question is with the computer, can i just buy a comp out of a 350 tpi car? i know it wont run right with the 305 comp in there. any advise?
Old Feb 28, 2004 | 12:59 AM
cdartz's Avatar
The ECM for a 305 TPI and a 350 TPI are the same (assuming they are the same year). It's the PROM that's different. You will need fuel injectors for a 350, and a 350 PROM, that's it.
Old Feb 28, 2004 | 07:50 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Go your local Chevy Dealer and buy a 350 TPI Prom (chip) for your Model year car. Cost about $60, this will get you up and running without spending money for a custom chip.
Old Feb 28, 2004 | 09:36 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
What about the Knock Sensor?
Old Feb 28, 2004 | 09:47 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You need a one for an L98. Also I am not positive on this but I think the ignition modules are different.
Old Feb 28, 2004 | 10:31 AM
Kontrax's Avatar
Car: 86 Camaro
sounds good. i dont know a lot about the tpi cars, im a carbed man i see all these pictures of people taking the emo stuff off and id also like to do all that. i thought that stuff would effect the computer though.
Old Feb 28, 2004 | 12:07 PM
DJP87Z28's Avatar
Read more about the 305 TPI to a 350 swap. You may need a few other items besides the chip. Did the same swap.
Old Mar 16, 2004 | 04:11 PM
Ross1577's Avatar
Car: 1985 Trans Am
I am doing the same swap right now, The only problem I have ran into is the fact that I stepped up to #30 injectors. Is your TPI setup MAF or MAP sensor? What year? The reason I ask this is 'cause everything I have found shows that MAF will handle about a 10% increase in displacement without problems. I have MAF & will have to have a chip burned
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
