LS1 swap, is it really much harder then the LT1?
Old Mar 5, 2004 | 05:36 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
alright guys, why is the LS1 swap so frawned upon? Is it really that much harder todo than a LT1 even though you can buy the motor mounts, the crossmeber and all the stuff needed?
I mean i used to want a good LT1 and stuff make it get atleast 320HP, but the ls1 puts out 350HP(320 was underated) stock and prolly wont be much more money cuase the LT1 is gonna have to be modded to get those power outputs, but then fuel economy goes to ****.
I can get a low milage LS1 for $950($1000 with tranny) at the local junk yard, the motor mounts and crossmember for $249, and i dont know about the wiring harness just yet, would i need a new one or can the old be used?
That would mean fro the most important parts so far i'd need $1249 bucks. But i need fuel lines, ps lines, ps reservoir, radiator hoses, prolly a vats bypass, and some notching to do. Since notching is free and vats bypass is $10 on ebay that would be clsoe to $325.
What else would i need? I knwo the swap is complicated but i'm open to any suggestions.
The LS1 is a good engine as long as i get a good one, some of them came with bad oil pumps and the such.
Thanks,
Shane
Old Mar 5, 2004 | 05:42 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Not to be rude, but all I can say is read the stickies, it explains just about everything.
Old Mar 5, 2004 | 06:16 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
That is cheap for an engine and transmission. I would get it. Now that the mounts are available from spohn the difficulty level is about the same.
Old Mar 5, 2004 | 06:18 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
cool i've been looking at a lot of liturature on these enigne now that i discovered the public library, so cool. I think the LS1 swap will be a much better bet fro keeping fuel effiency in ahigh power car.
Shane
Old Mar 5, 2004 | 08:47 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
one more quick question-
Everyone reccomends the new harness, is there a way i can use the old one? I am gonan get it reprogrammed, so vats isn't a worry really i just need to know if its mandatory.
Does it just make it look cleaner(ie newer wires), or is there something i dont know about? Wouldn't it use the relays i got anyways?
Thanks,
Shane
Old Mar 8, 2004 | 10:48 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Orrrrrrrr, you could buy the motor, sell off the intake and harness, buy a carbed intake from eldebrock, drop her it without having to worry about the harness and be good to go lol....
a carbed LS1 mmmmmmmm
Old Mar 8, 2004 | 01:31 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You could build your own harness by blending an LS1 harness with your factory one. I think the reason most people shy away from the LS1 is because of cost. If you can get one for that cost- go for it. I can't find one around here for less than $2000 plus they want another $1000 for a transmission. I am planning on putting one in my 87 when I have the money, so I have been doing research. Most people I have read about usually disable the VATS by having it programed out as well as some of the other LS1 specific emissions devices. I knew there was an intake to car an LT1 but I have never seen one for an LS1.
Old Mar 10, 2004 | 09:38 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well i wanted to blend in the LS1 harness but i'm not the best at wiring, i mean if i know what stuff goes to i can do it but i dunno if the wiring in our cars is well marked off. Are secific colors supposed to goto a certain thing? It might be a little easier if i was able to see diagrams of the PCM we got and the wires comapred to the LS1 ECM. Might make it easier to put together in my head. I might get somebody to help me do it becuas esomeone was gonna come up from tampa(i live in jacksonville) and help me out with the LT1 swap idea. I dunno if i want the LT1 anymore. SO mnay benifits to the LS1. They will both stat tlo bay back money spent with gas saving so there is a big plus.
I might just need to save up the $2500 needed for the swap, and just try it. Cant hurt naything. I'll eventually get it done.
Thanks,
Shane
P.S. there is no possible way to carb a LS1, there is no manifold nor manner to go about doing that. Completely different design engine, Period.
Old Mar 10, 2004 | 11:02 AM
cgb's Avatar
cgb
Wanna bet??
http://www.edelbrock.com/automotive/...manifolds.html
Performer RPM LS1 Carbureted Manifold
This powerful new manifold is designed for the popular Chevrolet LS1 (5.7L) small-block V8 originally used in 1996 and later Corvettes and 1997-02 Camaros and Firebirds. It also fits the Corvette ZO6 engine and any other Gen III engines including the LM7 (5.3L), LR4 (4.8L), and LQ4 (6.0L). The Performer RPM LS1 manifold allows the use of a carburetor on these originally computer-controlled engines, offering maximum power and a broad torque curve, providing optimum performance from 1500 to 6500 rpm. This manifold includes a unique electronic Timing Control Module made by MSD® which works with OE sensors to fire the “distributorless” ignition system and offers a choice of three timing curves. We have also included a special throttle and trans bracket that works with 700R-4 and Turbo 350 transmissions making the LS1 engine an easy retro-fit into any muscle car, street rod or marine application.
Baaannhh...wrong answer. Thanks for playing.
Old Mar 10, 2004 | 11:46 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
you will still have to get their wire harness to run the ignition system and the idea of converting a fuel injected engine to carb just for ease of tuning is just insane,step into the millenium carbs belong on race cars and/or museums with the other prehistoric collections.
Old Mar 10, 2004 | 11:57 AM
pasky's Avatar
Wow, thats one of the most retarded things I have ever heard. I mean im all for fuel injection, but to bash on carbs like that....thats true ignorance.
Old Mar 10, 2004 | 03:05 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
man pasky, your my boy, but i gotta say when your wrong. Fuel injection is the shizznicks. Carb is gone, never will have a come back, only people still using it are motorcycles and race cars. I mean new things. Carb gay way to TBi which gay way to PFI, its a cycle, wonder what will put PFi out, dunnop what the next step is, but for sure carb is gone.
Shane
Old Mar 10, 2004 | 04:04 PM
StealthElephant's Avatar
Car: 87' Iroc
kidrcth....have you ever taken a look around this forum? Theres probably just as many guys running carbs as there are EFI guys.
Old Mar 10, 2004 | 04:14 PM
pasky's Avatar
Shane
I never said Carb was better than fuel injection, read my post again. All im saying is that it is ignorant to bash on carbs the way he did.
1984HO
Mar 19, 2021 11:59 AM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
