LS1 vs LS6
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
If your talking an LS6 out of a vette, the oil pans are different and the swap is much harder than doing a ls1. Just buy an LS1 then do the conversion....I think this is even talked about in the stickies, too many repetitive posts =/,
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I *THINK* that the only big difference between the LS1 and LS6 are the intake, heads, and cam. Correct me if I'm wrong, but I think the base engine is the same. So yes, the oil pan should fit. Might wanna wait for someone who's sure to chime in tho.:lala:
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by pasky
Like I said, if you got the LS6 out of a vette, the oil pan is different.
Thanks shifty, yea I never said they couldn't and knew you could use a f-body oil pain, but like I said its discussed in the stickies and thier are so many repetitive posts as of late =/.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Actually even the LS1 Vette's have the different oil pan. They did so because in testing for the Vette, which is GMs road racing king, they found that the crank was getting starved in the corners, so they added the wings to accomidate for that.
