454 small block
Old Mar 14, 2004 | 01:26 PM
Renegade_Brad's Avatar
Car: 1986 Pontiac Trans Am
Engine: V8 305 TPI 5.0L
454 small block
Does anyone here have a 454 small block in there 3rd gen.
Old Mar 14, 2004 | 03:50 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I thought a 454 was a big block. There's a guy in Houston that's got a 454 in his T/A. I don't think he posts here though...
Old Mar 14, 2004 | 04:02 PM
TexasLT1's Avatar
Car: '92 RS
you can make a 454 small block. and no one that I know of has one. BADDEST305 has a 434 small block, but I don't think anyone has anything bigger.
Old Mar 14, 2004 | 09:40 PM
Merlin Hardcore makes a 454 small block that gets 600 hp
Old Mar 14, 2004 | 10:25 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i think there's a 472 small block out there now.....crazy huh???
Old Mar 15, 2004 | 01:56 PM
nolanr0413's Avatar
Car: Trans am
yeah 472 is now the biggest, shafroff makes the engine. They use a hardcore 415 block and then bore and stroke it. I would just love to put one in my car and then throw a set of valve covers that say 350 on them , no one would be the wiser.
Old Mar 15, 2004 | 04:31 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Guy I work with has a 454 SBC (Merlin Block I think) in a 78 Malibu. Runs high 9's in the quarter. Strip only trailer queen, but fast!!
Old Mar 15, 2004 | 04:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It's not Shafroff. It's www.Shafiroff.com
You won't find it on their website though. For some reason it isn't on there. At least I can't find it.
Old Mar 15, 2004 | 05:04 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Actually, you can bore and stroke a Motown 427 block (small block) and make 500 cubes. It's been done.
Old Mar 15, 2004 | 09:15 PM
TexasLT1's Avatar
Car: '92 RS
you wouldn't happen to know the bore/stroke combo on that would you?
Old Mar 15, 2004 | 10:16 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
This is the biggest SB I have seen in print from SpeedoMotive
481 CUBIC INCH FORGED CRANK KIT $2725.00
THIS CRANK KIT REQUIRES A DART IRON EAGLE TALL DECK BLOCK. ALL BRAND NAME PARTS WITH CUSTOM PISTONS ALLOWING YOU TO DESIGN YOUR OWN COMPRESSION RATIO
4340 FORGED 4.125: STROKER CRANK LITE-WT. 52# HEAT TREATED, NITRIDED AND 4 LIGHTENING HOLES
4340 FORGED 6.250" H-BEAM RODS WITH 7/16 ARP CAP SCREW BOLTS, FULL FLOATING
CUSTOM FORGED 4.310" PISTONS, LITE-WT. CNC MACHINED, FORGED PIN OILERS, DESIGN YOUR OWN COMPRESSION RATIO
TOTAL SEAL TSI RACE RING SET
CLEVITE H-SERIES MAIN & ROD BEARING
To get to 500 CI, you would need a 4.33 bore, and 4.25 stroke. Not sure that the bore is too safe that thin...
481
Old Mar 15, 2004 | 10:33 PM
TexasLT1's Avatar
Car: '92 RS
Thats what I thought, I was under the impression 48x was the biggest you could get and still have a useable block.
Old Mar 18, 2004 | 01:14 PM
vampiroc's Avatar
Car: Z28
with an engine like that you're limited to 18*/15* or SB2 heads if you want to get them enough air. 23* Small block heads are too small for a 454 ci IMO. you could make 600 HP with a 383 or 355 for much cheaper than a 454 SBC
Old Apr 9, 2004 | 07:56 AM
Randel '86's Avatar
Car: '89 IROC-Z
guys, you could probably bore and stroke a small block all the way out to a 502, that doesn't mean it's a great idea. I find it hard to digest that 454 or 472 is gonna be able to take much mod's at all, or even not over heat stock as is. I'd be careful, generally anything over a 427 sb is not recommended.
Old Apr 14, 2004 | 08:26 PM
bbunting's Avatar
Car: 1990 IROC Z
CHEVY High Performance, June edition, page 56. Says it all.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
64goatman
Sep 9, 2015 01:09 PM
84 TA NV
Sep 6, 2015 08:02 PM
