engine swap
Old Mar 24, 2004 | 12:35 PM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
engine swap
anybody ever heard of a NorthStar swapped to 3gen??
Sounds interesting but don't know how feasable it would be. I think the engine would be less expensive than LT-1 or LS-1.
Old Mar 24, 2004 | 09:16 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
arnt those front wheel drive engines? your talking about in the caddys right?
Old Mar 24, 2004 | 11:01 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
They are also in the rear wheel drive SRX sport utility vehicles FYI. I'm sure the LT or LS engine swaps would not be as expensive as the northstar.
Old Mar 25, 2004 | 01:01 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
There are a couple people doing that around here. There are even carb intakes for them too. I'll seeabout finding the name of he that is doing the swap now. He got some down right nifty headers for it too.
Old Mar 25, 2004 | 06:56 AM
hitman's Avatar
found it
on the web while surfing about engine swaps. It didn't give much detail but I believe a guy stuffed that 32V DOHC engine inside a 4th gen firebird. It got me to think and consider if cost would be more reasonable than LS-1 swap. The NorthStar I belive puts out about 300hp stock.
Old Mar 25, 2004 | 08:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I hate to be a broken record, guys, but a quick search on this Board came up with these:
https://www.thirdgen.org/techbb2/sho...threadid=28891
https://www.thirdgen.org/techbb2/sho...hreadid=146387
https://www.thirdgen.org/techbb2/sho...hreadid=161865
https://www.thirdgen.org/techbb2/sho...hreadid=183494
https://www.thirdgen.org/techbb2/sho...hreadid=218593
If you limit the search to "northstar" in titles only, you'll get 12 hits. If you search entire posts, you'll get 275.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
