Random Questions
Old Mar 26, 2004 | 02:30 AM
g_ride's Avatar
Car: modified 83 berlinetta
Transmission: TH350
Random Questions
Did 2.8 and 305/350 cars have different length throttle cables ?
Also if Im taking the cruise control out of my car(83 berlinetta), is it hooked up to anything else elctrically, or can I pretty much cut and tie off the wires?
... and I can't recall the other questions I had right now, but Im sure I'll have more later.
Ayways any help would be greatly appricated.
Old Mar 26, 2004 | 12:32 PM
g_ride's Avatar
Transmission: TH350
also on heat from exhaust - my headers are cooking my plug wires and such, any idea's around that?
Old Mar 26, 2004 | 03:35 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I do not think the trottle cables were different lengths, however I am not 100 percent sure.
My TPI car had an electronic interface to the curise control actuator. If it has wires going to it it will have to interface with the PCM
As for the wires get some of that aluminum like wrap and put it around the plug wires.
Old Mar 27, 2004 | 12:34 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Just don't let your plug wires touch the headers. If they don't touch them, they shouldn't burn.
If you can't fix that problem, get some of the steel plug wire boot-covers that the LT1 engines came with on the 4thgen cars.
Cornholio7979
Sep 20, 2018 02:31 AM
777Shock777
Oct 29, 2015 04:30 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
