what oil should i use
Transmission: 4L80E/4L80E
When you have a choice, go for the lighter oil. 10W30 is what was recommended for warm temps in LT1's.
Car: 89 GTA
Engine: 350 LT1
you hear all kinds of stories.. and this is 1. .
I once read that it is not a good idea to use 10w40 in vehicle engines because of the additives used to get the 10-40 split. I'm not asking for flames hear.. that's just what I read.. And personally, I just go with mobil 1 for brand.. and 10w30.. that's my pick, and everybody has a different opinion.
I once read that it is not a good idea to use 10w40 in vehicle engines because of the additives used to get the 10-40 split. I'm not asking for flames hear.. that's just what I read.. And personally, I just go with mobil 1 for brand.. and 10w30.. that's my pick, and everybody has a different opinion. Member
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
did you just rebuild the LT1? if so, you can't put synthetic oil in it. Use 10W-30. If not, the cylinders will never seal up with synthetic oil.
Car: 89 GTA
Engine: 350 LT1
also heard that that doesn't matter either..
but I would save a few bucks put reg oil in and don't even think about synthetic until the 1st oil change.. my bad there.
but I would save a few bucks put reg oil in and don't even think about synthetic until the 1st oil change.. my bad there. Last edited by Thirim; Apr 11, 2004 at 09:59 PM.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I would use dinosaur sauce (read: mineral oil) for break in, because its not as good as synthetic. It will take forever to break in, if at all, with synthetic.
Break it in with regular oil, then use synthetic after break-in
skinny z
Oct 5, 2015 06:23 PM
