Best motor for a 84 Trans Am
Old Apr 12, 2004 | 11:48 PM
crack3rjack's Avatar
Car: 86 trans am
Transmission: 5 speed
i might be picking up an 84 body, no motor no trans. what motors should i consider. i want to drag, but still be street driven and also im short on cash, so chaper might be better.
and 2) what type of (manual) trannys would be able to hold high horsepower for that motor?
Old Apr 12, 2004 | 11:50 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
I am no expert but most likely a 350 with either a built up T-5 or T-56 depending on application and how much $$
Old Apr 13, 2004 | 09:59 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
for cheaper, go with a gen I sbc , and carb'd it doesn't Have to be 4 bolt.. If you get serious you can 4 bolt it later.. and apparently makes a stronger 4 bolt. but if you can find 1 for cheap.. by all means.
Old Apr 13, 2004 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Best motor for a 84 Trans Am
Originally posted by crack3rjack
... im short on cash...
... what type of (manual) trannys would be able to hold high horsepower for that motor?
Those two pieces will not go together.
There is no "cheap" manual transmission that will hold up to high horsepower. If you do have a manual that can handle high horsepower, the rear end won't. It's not up to the shock of high horsepower manual launches, and getting one in that is will run you a couple grand minumum.
The shortest distance between no engine/no transmission roller and street/strip is a 350 of some kind, carb'd, with automatic transmission. TH350's are cheaper and can take more abuse than TH700's. The rear end can handle more power than stock, but if you get above something in the 250 range you'd better figure on upgrades (gears, axles, crush sleeve eliminator, support cover) if you want it to last at all.
Old Apr 13, 2004 | 03:23 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I say 454 BBC and th400, if its not a street car, start hacking and modding. First do the swap, and then build a drag suspension to take the power.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 13, 2015 12:59 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Leggman1
Aug 6, 2015 04:15 AM
