LS1 in 89 camaro
Old Apr 13, 2004 | 05:36 PM
89-305's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: automatic
LS1 in 89 camaro
would the vette ls1 fit in the fbody camaro? what would i need to make it fit
Old Apr 13, 2004 | 07:12 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
yes it would, search for a member named FLYNLOW92rs, he just had the conversion done and search for StngKlr he is in the process of the swap.
https://www.thirdgen.org/techbb2/sho...hreadid=227703
here's stngklrs thread
Old Apr 13, 2004 | 07:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I will move this to the right forum for you. You need to do some heavy mods for this swap to work but it can be done. I would start by reading the sticky's at the top of the page.
Old Apr 14, 2004 | 04:48 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Yeah I'm in the process right now and the end is finally in sight. As far as the motor swap goes, you need different motor mounts and tranny crossmember, which can be purchased at www.thirdgenresource.com You can do the wiring yourself (if so inclined), or send your LS1 harness and old harness to www.Speartech.com and have them mate the two together. You will need some exhaust work done. And you will need to upgrade the fuel system as the LS1 needs around 60 psi.
Theres alot more info on this board about the swap as mentioned before. Also check out the Hybrid section on www.LS1Tech.com theres alot of info on the swap there two.
My "project" is taking me a little longer than most, as there has been some minor but many setbacks. Also the car was totally gutted, so now I'm in the process of acquiring interior pieces to make it totally road worthy.
Good luck on the swap.
Old Apr 14, 2004 | 10:34 PM
FLYNLOW92rs's Avatar
You will also need a new tranny as the LS1 doesn't bolt up to theh T5 or TH400
Although i would highly suggest just using the LS1 from the Camaro/Firebird as the Corvette one will not fit because of the oil pan..........
You need a lot of misc parts and pretty much everything from the SBC can't be re-used for the LS1
Any specific questions?
Old Apr 17, 2004 | 12:55 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
You guys have to realise that the Vette LS1/LS6 has the assessories in diffrerent locations. The Vette has the Alternator on the top where the Camaro/Firebird would have the Power Steering pump. The Vette PS pump is then in a different location. You would have to check for clearance on those before, because I dont know of the clearance of a Vette setup.
Old Apr 17, 2004 | 01:01 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
And the oil pan is different as FlynLow states... BUT the TH350, TH400 and the 700R4 will all bolt up to the LS1 as I am doing so. The only problem is the Torque Converter, but there are flexplate adaptor plates out there to fix this, as I also have on of those.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
reiderz iroc
Aug 13, 2015 04:57 PM
