327 or 350
Old Apr 13, 2004 | 10:53 PM
thirdgenner05's Avatar
Car: 89 t/a
327 or 350
is it possible to put a tpi on both of these to work alright, will both engines bolt in fairly easy? which will perform better and which will cost more? Im lookin to get 12s maybe 11s with some go juice thanks.
Jason
Old Apr 14, 2004 | 03:22 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The external dimentions of a 327 and a 350 are ideantical, so both will fit. A TPI setup will work on both as well, since both have the same bore, so the computer should work fine on the 327 and 350. The 350 will make more power, and it will also cost less to build.
Build the 350, you'll be much happier and have alot more pocket change left for the kick-***-gas
Old Apr 14, 2004 | 04:46 AM
ede's Avatar
ede
built the 350 there isn't anything a 327 can do that a 350 can't do better.
Old Apr 14, 2004 | 07:19 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If I had a 327 and had to buy a builder 350, I'd go with the 327, even if I had to spend more for the rebuild parts than I would for the same 350 parts. Uunless I could buy a 350 for the difference in parts costs, then I'd get the 350 even if I already had a 327.
But, I don't have either, nor the money right now to get either, so it's a moot point for me.
TX-SleeperC5
Feb 24, 2016 01:34 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
84 TA NV
Sep 6, 2015 08:02 PM
Formula_88AE
Sep 3, 2015 01:47 PM
