305 or 350
Old Apr 18, 2004 | 07:18 PM
2litereater's Avatar
Car: 1984 Trans Am
Transmission: T-5 w/3:73 gears
305 or 350
Does anyone know how to tell the difference between a 305 small block and a 350 small block without trying to get a the casting number?
Old Apr 18, 2004 | 07:27 PM
jmd88iroc-z's Avatar
Car: '88 IROC-Z
Engine: 305 tpi
Transmission: 700r4/OD
Is the motor in the car? Is it the motor that came with the car?
If you're talking about the appearence differences, the only way (that I know of) is pull the heads and check cylinder bore. I'm sure some of these gurus can tell you another way.
Sometimes the VIN # on the car can tell you, if it is the original engine in the car.
Old Apr 18, 2004 | 07:37 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Some of them have 5.0 or 5.7 cast into the side of the block. You can also pull a valve cover and look at the last 3 numbers of the head casting. That is only a rough idea beause some people use 305 heads on a 350.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
