305 - larger engine
Car: 92 Camaro
Engine: 305 TBI
Transmission: 5 speed manual
305 - larger engine
hey everyone, I was wondering what kind of engine would be easiest to install and will still give me some good power. I have a 92 RS with the 305 in it and I want to swap it out for at least a 350. I have a budget of about $2,800 just to spend on the engine because I can install myself. Does anyone have any suggestions on what I should get? Thanks in advance!
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Easiest - SBC have the same external dimension.. 350/383/400 Good power - Done
Budget - It depends on the parts you pick ..
The 350 HO goes for around 2k
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would take that 2800 bucks and spend it on a full exhuast, upgraded fuel system, suspension stuff, and chip burning stuff. After that your car will be prepped to handle more power. These cars have a tremendous amount of weak links and the first thing to do is adress them before you add any real power.
Car: 83Z28 HO
Transmission: G Force 5 speed
Car: 92 Camaro
Engine: 305 TBI
Engine: 3.0L/183
ShiftyCapone does make a good point.. prep the car for
the futur power.. tho since you're 5L is dead.. got to
start there..
350 cu.in, light flexplate, torque converter , trans upgrade, and rear upgrade.
Then, you save up for the suspension ...
start there..
Car: 92 Camaro
Engine: 305 TBI
Engine: 3.0L/183
http://www.streetrodstuff.com/Products/166/
http://www.goautocenter.com/330hp_vortec.htm
cheaper at the second one for a reason ..
Tho the add ons are going to exceed the budget ..
NinjaNife
Aug 23, 2015 11:49 AM
