What 350 to look for?
Old Apr 22, 2004 | 09:14 PM
dwillms's Avatar
Car: 90 Integra
Engine: B18
Transmission: 5-speed
Hello,
I have an '86 Trans Am that I got as a parts car with my daily-driver 86 TA. The seller ripped out the 305 TPI, computer, and wiring. Since I live in Canada, and a TPI setup is retardedly expensive to gather up where I live, I'd like to chuck a cheap carb'd small-block in.
My question is, what kind of cheap 350 small-block should I be on the lookout for? If I buy from a junkyard or from a private seller, are there any specific engines(ex. from truck, thirdgen, etc.) that I should look for? What kind of price for a running 350 is a decent price to pay? Thanks again,
-Dustin
Old Apr 24, 2004 | 11:24 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
Find one with a four bolt main. I got mine from a piece of **** 1985 and rebuilt the entire thing for my 88. Everything except the block and crank is new. The price will depend on whether you want it running or not, just make sure the block and heads are intact. New heads will run at least $700. I unfortunately, had to get new steel heads, my iron ones were cracked, easy $800.
Old Apr 25, 2004 | 12:35 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Is it going to be dropped in as-is, or are you going to rework the engine after you get it?
If you want 4 bolt mains, check out truck engines, they are most commonly there.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
