oil fiter adapter
Old Apr 24, 2004 | 06:23 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
oil fiter adapter
I installing my new ZZ4. The ZZ4 did not come with a oil fiter adapter, so I had to scavenge it from my old motor. The problem that I am having is I can't remember which way it bolts in. There are two ways in which it will bolt in. Does it matter? Can it bolt in either way?
Old Apr 24, 2004 | 08:35 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
It really doesn't matter which way it goes in, but I like to place the by-pass valve opposite of the oil pump supply port.
Old Apr 25, 2004 | 06:35 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Ok thanks. Thats the way I will do it.
Old Apr 27, 2004 | 10:38 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Just a friendly warning. It is fairly rare but the bypass valves can go bad. I trashed a $2200 short block when my bypass valve broke allowing unfiltered oil to circulate during the critical break-in period. Competition products sells them new for $6.95. Cheap insurance, for sure.
Another option that I personally use is plugging the bypass valve. You can pop off the retaining plate, disgard both the spring and plate. Then tap the hole for the appropriate NPT plug. I believe it's 3/8". Thread in the plug with permanent Loc-Tite.You have to change the oil regularly and I highly recommend a K&N oil filter or equivalent that can flow lots of oil. This insures every drop of oil through your engine will go through the filter before traveling through your motor. I don't recommend this method for places with harsh winters where your oil becomes sluggish.
b4ccamaro
Jun 5, 2016 01:48 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
romcjr
Sep 17, 2015 05:18 PM
