Bye bye 2.8 hello v8 tpi
Old Apr 28, 2004 | 06:39 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Not sure on the year or anything but today the guy around the corner from me ( who has a 11 second 79 camaro and a clean rs with a carbon fiber hood etc) knocked on my door and asked of i wanted to buy a motor.
I went and looked at it and its a tpi motor, trans , ecm and all. Just need the wiring harness that goes to the inj.
ALL FOR $300!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'll spare you the long story of why hes selling it. Needless to say i can not lest this go , friday im picking it up. My question is i know the basics, the motor mounts, the rad, and obviously if im keeping the tpi injection i need the wire i mentioned. My question is anything else you guys think i should be aware of?
Thanks.
Old Apr 28, 2004 | 11:32 PM
br()bert's Avatar
Car: 85 firebird
anyone?
Old Apr 29, 2004 | 01:54 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
sweet deal man!:hail:
you might need a beefier fuel pump to feed the tpi... thats all i can think of at the moment...
Old Apr 29, 2004 | 01:01 PM
br()bert's Avatar
Car: 85 firebird
I've been thinking about going carb'd alot.
Old Apr 29, 2004 | 02:03 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i did the saame thing! definently do it
Old Apr 29, 2004 | 02:06 PM
br()bert's Avatar
Car: 85 firebird
you did what? ,went from v6 to v8 carb or tpi to carb?
The carb option is really so simple compared to the tpi setup with the vats issue. Plus the carb gives more upper end power from what i have read. Plus im so tired of all these sensors etc.
Old Apr 29, 2004 | 02:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Bye bye 2.8 hello v8 tpi
The sticky at the top of the forum.
Old Apr 29, 2004 | 04:08 PM
br()bert's Avatar
Car: 85 firebird
I've read that. Sometimes you forget the little things, something might not be included in the sticky. Believe me i hate it when someone askes
"what do i gotta do to do a v6 to v8 swap"
Im wondering if a carb is a better option. Im wondering whats everyones opinion on carbed instead of the tpi? etc.
Old Apr 29, 2004 | 05:56 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
i went from a 2.8 v6 mpfi to a carbed 350 v8. the swaitching over to carbeurated was tough for me and confusing. mayb thats just because it was the first time i had done something like this.
Old Apr 29, 2004 | 06:05 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Why would you want to go carb when you already have the FI intake? Thats crazy. Besides the TPI wiring harness is not much different than the v6, infact I used a v8 wiring diagram to do my swap. Just go TPI.
Old Apr 29, 2004 | 08:02 PM
br()bert's Avatar
Car: 85 firebird
I have the motor now, The guy brought it around. He gave me the motor/tran still bolted together, the ecm, an extra drive shaft,
a v8 rad, the starter, motor mounts,even the air tubing and filter box with a k&n. AND i didnt even pay him for it yet!
BUT
I am missing the wiring that goes from the ecm to all the sensors etc. When i look for it online its like $200-$300!!!!!!
In no way am i complaining, i still got a great deal! But its either i pay for the harness or go with carb right?
Old Apr 29, 2004 | 08:13 PM
pasky's Avatar
Check car-parts.com. Unless your really into carbs, there is no reason you shouldn't spend the extra 100-200 dollars on a wiring harness. You'd probably end up paying the same amoutn to buy a carb intake and carburator/filter, not to mention you may need to change the throttle cable and fuel pump and get a regulator.
Old Apr 29, 2004 | 10:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Old Apr 29, 2004 | 10:39 PM
br()bert's Avatar
Car: 85 firebird
my cam sucks but heres some pics of the ecm the rad the drive shaft and the throttle cable thingy he gave me. Im looking around and getting prices now.
Old Apr 29, 2004 | 10:40 PM
br()bert's Avatar
Car: 85 firebird
Old May 5, 2004 | 01:23 AM
yamahaguy91's Avatar
Car: 88 camaro RS
Engine: that thing under the hood?
Transmission: a what????
you would spend more then 300.00 just to change it to carbed
carb= 220 at the least new
intake= at least 100
fuel pump= 40 for a cheap one
new gaskets= 20
theres theres 380 there and thats with out tax or shipping
the only way i would switch to carb is if your going for performance
Old May 5, 2004 | 01:29 AM
br()bert's Avatar
Car: 85 firebird
a friend has an intake i can use
A guy is supposed to get back to me about trading the tpi stuff for a carb
the afpr is 75
And the gaskets as you said
and yeah of course i want performance.
Old May 6, 2004 | 10:58 AM
br()bert's Avatar
Car: 85 firebird
some pics
Old May 6, 2004 | 11:00 AM
br()bert's Avatar
Car: 85 firebird
as soon as i sell this tpi stuff the motor is going in the firebird
Old May 6, 2004 | 11:08 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if your unsure if you will be able to do the tpi swap yourself you shouldnt be i would try and find a harness that you need at a salvage yard somewhere there are plenty tpi camaros in the junkyards man just go lookin around and see if you can find one before you jump the gun and sell a good tpi for a carb and intake set up you will regret it later i think.....
Old May 6, 2004 | 11:10 AM
br()bert's Avatar
Car: 85 firebird
why do you think id regret it later?
Also im positive i can do the tpi to carb swap, nothing to it really cept the afpr.
Old May 6, 2004 | 12:35 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
the swap is fun .... i jsut got mine running a few days ago...LOUD with just headers. if u have any questions u can pm me if you would like.
Old May 6, 2004 | 01:23 PM
br()bert's Avatar
Car: 85 firebird
Thanks man, ill do that.
Old May 6, 2004 | 02:18 PM
Car: 88 camaro RS
if your really looking to sell the TPI stuff let me know how much i have been thinking about going to FI (better gas mileage )
Old May 6, 2004 | 03:32 PM
br()bert's Avatar
Car: 85 firebird
Best offer really, i have two people looking at it now, one appears to be a window shopper, the other one i dont know.
Old May 6, 2004 | 11:44 PM
br()bert's Avatar
Car: 85 firebird
Id take any reasonable offer. Not trying to make alot out of it, just trying to help out with the cost of the stuff i need to buy.
Or a trade.
Old May 7, 2004 | 12:15 AM
THEGENERAL's Avatar
not sayin you cant do the tpi to carb swap
just sayin id try and make the tpi work is all ...you will enjoy the tpi alot more than the carb in my opinion
Old May 7, 2004 | 04:53 PM
Mertin's Avatar
Car: 88 Firebird
Engine: 2.8L v6
Transmission: 5 Speed
wow what a find.. ive been searching boards allover for this..
ive got an 88 bird' with 2.8L and i wanna put my 350 from my 76' bird in there.. what other mods did u have to do?
New rearend?
is there conversion motor mounts available?
drive shaft shorting? lenthening?
what about beefing up the suspension? because i heard somwhere that the fbodys that came with v8s and t-tops had some extra support somwhere?
wow this is cool i wanna dive right into my swap now
Old May 7, 2004 | 05:01 PM
br()bert's Avatar
Car: 85 firebird
uhm , no the rear stays.
Unbolt the v6 mounts throw them away. If you look right infront of the v6 mounts you'll see the holes for the v8 mounts.
I have the srive shaft from the car my v8 came out of, its the same size as the drive shaft thats in my car now so that stays.
Sub frame connectors are a good idea no matter what motor is in your 3rd gen, but also some people change the front springs once they drop in a v8 because the v8 is a little heavier.
Its not that hard of a swap really. Also my car has an electric fuel pump for the FI, so ill need a adjustable fuel pressure regulator so the carb isnt getting 45 lbs psi!
Uhm, a home made or after market lock up switch for the tq converter if you like. Theirs a sticky at the top. It explains alot.
Old May 18, 2004 | 01:12 PM
br()bert's Avatar
Car: 85 firebird
So far. I got $300 for the TPI stuff which is what i paid for the complete motor and trans. I spent about $300 on a carb adapter,
plugs,wires,cap,rotor,oil,antifreeze,gaskets,throttle bracket,
alt bracket and other stuff.
If i didnt get alot of the stuff needed to do the swap from the guy i got the motor from I could have easily spent double what i have.
The motor will have a new edelbrock performer rpm intake with a new holley 650.
From the manifold to engine surface to the top of the carb is 10 inches. A friend and I measured and it looks like i have 12 to play with before anything will hit the hood. Ill probably need a drop base air filter.
Im waiting on summit to send me my afpr then im ready to pull the half dead 2.8.
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
breathment
Nov 11, 2001 10:42 PM
Snuffit
Apr 30, 2001 11:54 PM
branz28
Oct 22, 2000 08:06 PM
Vader
Oct 18, 2000 08:32 PM
