fleetwood 94 5.7 V8
Old Apr 30, 2004 | 12:45 AM
Its the ROC's Avatar
Car: then:1986 Z/28 now: 95 Trans Am
Transmission: TH-700R
fleetwood 94 5.7 V8
would that engine fit right into a 86 IROC? the guy im buying it off of said it will fit the original motor mounts and will hook right up to the TH-700R tranny in my ROC. m kinda new to the whole engine swap so i wanted to ask the experts, and i have a TPI unit too and he said that will slap rigt on to the engine, ANY COMMENTS ARE WELCOMED. i just dont wanna get a engine that i cant use. thanks
Old Apr 30, 2004 | 10:26 AM
Drakar's Avatar
Im almost positive the Fleetwood in 94 got an LT1 same as the Caprice/Impala/Roadmaster/Custom Cruiser
Check the VIN if you can 8th digit should be a "P" and of course if you can check RPO's its LT1
In which case if it IS an LT1 - No your TPI won't work, but yes your 700 will with all the usual issues of swaping an LT1.
Old Apr 30, 2004 | 04:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If it is an LT1, why even try to use TPI? You'll just lose all the benefit of going to an LT1.
Old Apr 30, 2004 | 04:58 PM
Drakar's Avatar
He couldn't use TPI on an LT1 anyways SBC I vs SBC II.
If he did get the motor it would be to just drop the LT1 in as others are doing including myself, and sell the TPI or use it for another project.
It's the ROC, who much is this guy asking for the engine, PCM wiring harness, accessories so on .... also can you get the tranny as well?
if you can get all that stuff for a good price, then it will make a fine swap in your car.
Old May 1, 2004 | 01:05 AM
Air_Adam's Avatar
I know... notice I said try...
Old May 1, 2004 | 11:40 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Make sure it is not the 4.8 LT1.
Old May 1, 2004 | 12:18 PM
TexasLT1's Avatar
Car: '92 RS
Actually he could just the same the LT1 intake is used on Gen 1 SBC. The question just comes up why you would want to.
Old May 2, 2004 | 12:42 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
If you give up trying to get the lt1 fuel injection working they sell carb intakes for the lt1 engines now.
Old May 2, 2004 | 10:28 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
these was never a 4.8L LT1
these was, however, a 4.3L
Old May 3, 2004 | 11:57 AM
Drakar's Avatar
And at that the Baby LT1 (4.3L) ONLY came in a caprice, never any other full size cars have I seen it offered, unless Im wrong ... not the first but im 99.9% sure I am right!!
Air Adam - sorry didn't see the try
Old May 4, 2004 | 12:30 PM
i'll have to check the VIN. but he said he'll sell the engine for 50$ but the TPI for 150$ ? he says the engine came out of some old ladys fleetwood so it not beat and has low milage. it just sounds to good to be true.. and i dont know if the car will pass emissions,im from california and our emission laws suck. thanks for all the input.
Old May 4, 2004 | 03:07 PM
Drakar's Avatar
Be certain it is a 94, as they look identical to 91-93 and those years got 5.7 TBI engines.
but if it is a true in true 94 it should be LT1 motivated.
Old May 4, 2004 | 04:26 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
ehhh..it is prolly a tbi
Old May 5, 2004 | 05:09 PM
well if it was TBI couldent i swap it out for TPI? im still really new to this whole engine swap..
Old May 5, 2004 | 05:19 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
No, you'd want an LT1 intake setup .
Old May 5, 2004 | 05:29 PM
Drakar's Avatar
HEHEHE yes you could use the TPI setup you have and as Pasky added you could pick up a converted LT1 intake from (drum roll please!!!!)
LT1intake.com
heheh, but you would want to pull the heads off the TBI 350 and throw them into the nearest river/swamp/rednecks back yard.
and find a decent set ... someone upgrading the L98 would have those heads and they aren't bad for stock casting.
So ya first off you need to confirm if it is a 350 TBI or LT1, and that's easy if it is in the car ... pop the hood, if you see the typical carb aircleaner you have TBI if you see a giant black homeplate looking plastic airbox ... you have LT1.
Old May 8, 2004 | 01:27 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Just to reiterate, all '94-'96 Fleetwood Broughams came with the 5.7 LT1 engine, before they (and the Caprice/Impala) were cancelled at the end of the '96 model year. '91-'93 Broughams had either the 305 or 350 TBI engine (LO3, LO5). I used to work at a Caddy dealer back in that era as a line mechanic. I remember driving those big ole land yachts, and they used to scoot pretty good with the LT1 engine.
blackz281le
Jan 11, 2016 07:51 AM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
usafirebird
Sep 29, 2015 11:58 PM
IROCtometal
Sep 9, 2015 10:01 AM
