Flywheel ?'s and other l05 questions
Old May 5, 2004 | 12:06 PM
Dan86Z28's Avatar
Hey fellas.. I'm lookin to put an l05 caprice engine in my 84 z that origionaly had the 5.0HO in it..
It's a 5 speed, and I was wondering if the flywheel is weighted differently for the newer (92) caprice engine than the one that was behind the HO
Any ideas?
Also what other problems will I run into?
Old May 5, 2004 | 12:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use an '86-up 3rd gen flywheel, no other problems there.
I understand the LO5 doesn't have any mechanical fuel pump provision (the mounting boss is there, but no machining for the rod).
Old May 5, 2004 | 07:56 PM
Dan86Z28's Avatar
so then all I'd have to do is use an electric pump, right?
Old May 5, 2004 | 09:22 PM
Dan86Z28's Avatar
One other thing...
I have a set of LB9 heads sitting around here.. what would putting those heads on this engine do?
I figure it'll raise the compression ratio, but how much?
Also, would it make any more power than the stock caprice heads?
What about head porting on the caprice heads? Worth it? Or just do a valve job on my LB9's and slap em on?
Old May 5, 2004 | 09:50 PM
five7kid's Avatar
Worth it to port the LB9 heads and put on the LO5. Even more so if you put in 1.94" intake valves while you're at it.
Not worth it to port the LO5 heads.
Old May 5, 2004 | 10:59 PM
Dan86Z28's Avatar
what would that bump my compression ratio up to?
Heck, what's the stock compression ratio on the l05?
Old May 5, 2004 | 11:10 PM
five7kid's Avatar
Around 9:1. Use thick composite gaskets, and unshroud the valves a little while doing the porting, and compression will be fine.
Old May 5, 2004 | 11:11 PM
Dan86Z28's Avatar
9:1 is stock?
or thats what I'd be at?
Old May 5, 2004 | 11:23 PM
five7kid's Avatar
The LO5 is around 9.0:1.
The L69 had 9.5:1, as did the '85-'86 LG4 and LB9.
Later engines like '87 LG4, '87-up LB9, L98, and LO3 had 9.3:1.
Old May 5, 2004 | 11:28 PM
Dan86Z28's Avatar
So if I just cleaned up these heads and bolted them on, what would I be looking at, compression ratio wise?
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
BBSDesigns
Aug 11, 2015 07:39 PM
