Tranny stuck to 350 block
Old May 14, 2004 | 12:38 PM
WhiteKid's Avatar
Car: 92 Firebird
Engine: TPI 350
I have a 350 TPI and am pulling the block....The block is completely stripped, motor mounts removed, bellhousing to block bolts removed all 6.....Try to pull the block and the tranny wants to come with it. Figured it was the clutch fork so I removed the push rod that pushes against the clutch fork. Cant get the clutch fork out??? How do I just pull the block without the tranny? Thanks
Old May 14, 2004 | 01:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
6 bolts is it. Shout be 3 on each side, none at the top middle.
It'll come out. It's probably just stuck on the dowel pins. The fork will stay behind, just leave it alone.
The bell housing, trans, fork, & throwout bearing will stay; the engine, flywheel, clutch, and disc will come out.
Old May 14, 2004 | 03:49 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
If it's giving you that much of a problem you can pull the 4 trans to bellhousing bolts and do it that way.
Old May 14, 2004 | 04:23 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Do you have something under the trans to support it? you should jack it up a little to take the pressure off the dowel pins like he said. Your also trying to pull the teeth on the clutch disc off the trans input shaft. You can try to loosen or remove the clutch bolts from the flywheel too! Don't be scared to shake it up a little they need to be persuaded some times!
Old May 17, 2004 | 11:53 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: Tranny stuck to 350 block
Pour a bucket of cold water on them!
Old May 17, 2004 | 12:43 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
GOOD ONE!
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
