need help finishing ls1 project
Old May 25, 2004 | 08:34 PM
silverta8702's Avatar
i was just wondering if anyone could help me with a few things as i finish up my ls1 , all i have left is getting fuel to it and a little wiring,. what do use do or use for fuel lines ? what needs power to start the car ? and what is the three wire connector wit the purple,,grey/red and one other color wire for ,its by all the power connectors . right now i have power /ign /grd to pcm / power to each injector bank . oh and what wire do i hook my bypass up to i need the data wire that usaaly is purple on the aldl plug. oh my engine is a 02 ls1/6speed going into an 87 trans am . thanks
Old May 26, 2004 | 01:29 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Awesome! You will love it. You can have someone weld the correct AN6? fittings on to the existing fuel line from the frame to the fuel rail. There is a thread that gives a better example of this I will post the link later. You can use the fuel pressure regulator to keep the return loop.
Replace the fuel pump while you are at it. Mine only lasted one month after my conversion was finished. Went with a walbro high volume in-tank unit.
https://www.thirdgen.org/techbb2/sho...5&pagenumber=2
Linson
Sep 21, 2015 01:08 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
ericjon262
Sep 11, 2015 06:07 PM
