LT1 Swap Pics
Car: 1987 Trans Am
Engine: Lt1
Originally posted by Z28*****
Nice work, looks good cept for all the smurf skin on your wiring
Congrats!
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks good, you've got it running right?
Car: 87 Iroc
Engine: Carbed LT1
I'm just waiting for the pcm to come back from Ion...Should have it fired up on tuesday...As far as the smurf skin...I had to do something...I cant stand wires hanging out everywhere.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
AHHH! blue!
lol, its in there and running.... cool.. how do ya like it? any probs?
im also not a fan of the blue stuff.... i would have used black.. but other then that, looks great.
Car: 87 Iroc
Engine: Carbed LT1
Its not running as of yet...I'm having trouble with spark and injectors...From the info i got, my problem is leading back to the opti...Its not sending a signal to the pcm the tell it to fire the coil and injector...I repaced the opti, But no dice....So I'm kinda clueless as of what to do now
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
Dean-B4C6SPD
do you have good clearance where you have the pcm? cause thats where i have mine at and i'm thinking the hood is hitting it.
Originally posted by z91bowtie1
Dean-B4C6SPD
Dean-B4C6SPD
But...my hood hinge may be higher than yours... I thought most 3rd genners do that on purpose..to "cowl" the heat out a bit...
But even then, I know there's a lot of clearance...
Engine: 96 LT1 5.7
do you have it bolted down or is it just stting there? i'm trying to figure outhow to bolt it down. what about your wires (spark plug that is) did you have to cut them to size or did you buy them like that? thanks for the info your engine setup looks like mine accept for the wires don't know what to get rid of
Champion copper plugs are pretty short as well as the Bosch Platinum Plus 4's - no cutting... I don't know they are worth the money, but they are short plugs...I'd rather pay .69 cents for Champion coppers than $5 a plug for the Plus 4's...too late.
Engine: 96 LT1 5.7
Dean-B4C6SPD
could you tell me about your spark plug wires. i would like to run mine like that. did you have to cut them to length or did you buy them already assembled and what brand are they thanks
Car: 1987 Trans Am
Engine: Lt1
Those look to be the Made For You ones(I got mine from Summit). I have them and am using Taylor plug wires. It really is a btter way to have the wires run.
Over the Valve Cover Wires
Engine: 96 LT1 5.7
Trans Am#5
do you think its better to keep the o2 sensors on or off? mine are turned off but don't know if i should have them turned back on.
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Your car will never go into closed loop and therefore you will be running rich and have very crappy gas milage. Unless of course your referring to rear oxygen sensors, they aren't necessary.
Car: 1987 Trans Am
Engine: Lt1
Trans Am#5
Trans Am#5
Engine: 96 LT1 5.7
we don't have emissions in indy. from what my paper work says it is the rear o2 sensors. where are these located? the only ones i know are the ones on the headers.
Dean-B4C6SPD
Dean-B4C6SPD
Very easy to make and they come in super long lengths. You have to buy the over the valve cover looms (with bolts) yourself, but every place sells stuff like that in different colors (blue) too!
Your arm will be in pain from all the crimping, but it's worth it and makes the engine compartment look clean and gives you more options if you run long tubes and you do not want your wires touching the runners...
Car: 1987 Trans Am
Engine: Lt1
Trans Am#5
what all did you have done to your pcm as far as turned off adjusted?
Trans Am#5
Engine: 96 LT1 5.7
Originally posted by Dean-B4C6SPD
Heh. I know some people cut their plugs, so I wrote about my plugs..hehe
Car: 1987 Trans Am
Engine: Lt1
Z91Bowtie...I can't find the list but some things I do remember:
None of the following are on:
A.I.R. Pump
HVAC
4L60E
Steering pressure switch
I'll try and scan it when I get time to see what is and isn't on. It's been a long time since I even looked at it and my computer in the garage may not even have the correct software for it on there anymore.
A.I.R. Pump
HVAC
4L60E
Engine: 96 LT1 5.7
trans am don't worry about it. thanks anyway. you think i should tell ion about my manual t5 five speed? i see you have 460le on yours. or will it matter?
