would these heads fit?????
Old May 31, 2004 | 07:39 PM
86z28stroker
Guest
Posts: n/a
I am rebuildin my 86 z28 and i was wondering if heads from a malibu that had a 305 in it would fit. The motor in my car is a 305 v8. Also would 350 heads fit on it?
Old May 31, 2004 | 08:25 PM
LT1guy's Avatar
Car: 1987 Trans Am
Re: would these heads fit?????
As long as its a pre-87, everything will physically bolt up without changing the intake, but depending on which heads you have the valves and combustion chambers may be different sizes than your originals. 350 heads will bolt up, but you'll usually lose compression (depending on what head it is) and the larger valve sizes may be shrouded, or worse. Id stick with 305 heads.
Old May 31, 2004 | 09:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yes, they will bolt on.
No, you don't want 350 heads on a 305. If you have a 350, then go nuts
The only difference between the '55-86 and '87+ SBC heads is this:
- A few of the intake bolts are drilled at a different angle on '87+. No big deal, just gotta get special washers to make them work with '55-86 intake.
- '87+ has centerbolt valve covers, '55-86 has 4 of them around the outside (*side note* '55-60 has two valve cover bolts in a slightly different spot than '61-86 heads)
Old Jun 1, 2004 | 10:50 AM
86z28stroker
Guest
Posts: n/a
thanks for your help
Old Jun 5, 2004 | 07:11 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
care to eleborate on these special washers? if that's all it took I'd be a happy man
Old Jun 5, 2004 | 10:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
These
http://www.sdpc2000.com/cart.asp?act...1818&pid=46994
Old Jun 5, 2004 | 11:46 PM
Air_Adam's Avatar
I don't see a pic at that link, but that sounds like them. And yes, thats all you need.
Old Jun 6, 2004 | 10:55 AM
Car: 1987 Trans Am
Engine: tree-fiddy
ok, it says they are for "Professional Products" manifolds and so, if he wanted to use say an edelbrock or holley intake those washers prob wont work, as I have seen exactly how far off the holes actually are. and no washer is going to make stock chevy intakes pre 87 fit post 87 heads.
Old Jun 6, 2004 | 10:52 PM
Air_Adam's Avatar
Originally posted by Dr.NickRiviera
No washer is going to make stock chevy intakes pre 87 fit post 87 heads.
Yes they will, I have seen them, they do exist and they do work.
Old Jun 7, 2004 | 12:04 PM
Car: 1987 Trans Am
Engine: tree-fiddy
can you find a picture, if that will work i'm all for it. I'm not trying to be an ***, it's just that i have seen the mismatch in parts and the holes were at different angles which kept the bolt from physically going trough the manifold and threading into the head, they were off by maybe 1/8"
Old Jun 7, 2004 | 01:57 PM
Air_Adam's Avatar
I don't have any pics, but the washers are sorta wedge-shaped.
Old Jun 7, 2004 | 05:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Elongate the holes in the intake manifold and put the washers under the bolt heads.
Old Jun 7, 2004 | 05:16 PM
five7kid's Avatar
Mid-year 1959 change, if memory serves.
Old Jun 7, 2004 | 05:33 PM
Air_Adam's Avatar
Meh, close enough
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
