Salvage yard 305 block
Old Jun 7, 2004 | 12:56 AM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
I'm going to call a few salvage yards to look for a 305 block to rebuild. After reading the boards for a few weeks, I see that you can fine tune a 305. My question is, what should i look for when i purchase the block..
Old Jun 7, 2004 | 06:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A 4" bore one.
It makes no economic sense to buy a 305 block to rebuild, unless you're racing in a class that requires it. And even then it usually makes more sense to just put a good junkyard short block in and run it until it blows up and then get another.
Old Jun 7, 2004 | 06:42 AM
FBodesigner's Avatar
From: I am all around you...even now...actually Japan, but don't tell anyone, it's a secret
Car: 90'300ZX/87'Formula (In Storage)
Engine: 300ZX:3.0LTT/Formula:5.0L
Transmission: 300ZX:Manual 5SPD/Formula:700R-4
RB83L69 is right but if you absolutely want to get a salvage 305 block then you will want to have the block magna fluxed to check for cracks or sonic tested to see if it is in good enough condition to warrant a rebuild instead of just waisting money...but displacement is the cheapest way to make horse power so it is entirely up to you as to how many cubes you go for. Good luck.
Old Jun 7, 2004 | 10:01 AM
ljnowell's Avatar
Here is what you do. Go to a reputable yard and purchase a used 305 shortblock, take it to the machine shop, and have everything checked. Probably need som cylinder work, get the thing done. Get some good heads and everything else that you need, and put it all together. Then when you are done, you will realize that you spent the same amount of money you would have with a 350 and have less power. just get a 350.
Old Jun 7, 2004 | 10:45 AM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
if your looking for a 305 short block I'll sell you mine for cheap
Old Jun 14, 2004 | 09:00 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
just post an add in the classifieds, someone will probably give you one.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
mhatfield 14
Oct 24, 2015 07:48 AM
nuggie
Aug 25, 2015 01:27 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
