swap?
Old Jun 7, 2004 | 03:51 PM
JoeMan's Avatar
Car: 1988 Trans Am GTA
Engine: LB9 (305)
swap?
hi i have an 88 gta how hard is it to swap a 305tpi to a 1987 350tbi and use the tpi from the 305?because i don't want to use the tbi. it should just fit in nicely right all i would have to change would be my computer chip and match the intake ports right? or am i missing some more stuff? well any info would help alot
Old Jun 7, 2004 | 05:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'87 350 TBI? What is this supposed to have come out of?
If it is a 350 TBI engine, the heads are terrible from a performance standpoint. No port matching required, though.
Old Jun 7, 2004 | 05:11 PM
JoeMan's Avatar
Engine: LB9 (305)
so should i just use the heads from my 305 and get them done up or look fo different heads?
Old Jun 7, 2004 | 05:13 PM
five7kid's Avatar
You could go either way, but using your current heads and having 1.94" intake valves installed would be a good route. Most likely the 350 has dished pistons, so the smaller 305 chambers would be a nice compression bump (similar to what the 305 has now).
Old Jun 7, 2004 | 05:18 PM
JoeMan's Avatar
Engine: LB9 (305)
ok cool so could i get them shaved as well? that would boost up the compression a bit to right
Old Jun 7, 2004 | 05:21 PM
JoeMan's Avatar
Engine: LB9 (305)
did they make a big block tbi
Old Jun 7, 2004 | 05:35 PM
five7kid's Avatar
No. The 58cc chambers are small enough.
Yes.
Old Jun 7, 2004 | 05:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yep, it was a 454. The 454 throttle body is a popular part for the 305 TBI crowd, or so I heard anyway.
Old Jun 7, 2004 | 05:40 PM
JoeMan's Avatar
Engine: LB9 (305)
ok so i found a 350 tbi in the paper i have to call him at 6 so i'll find out everythin. but if the 454 was the only tbi big block i should be ok
Old Jun 7, 2004 | 09:10 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
That 454 was a dog a** engine, and bad gas mileage to boot.
Old Jun 7, 2004 | 10:35 PM
Air_Adam's Avatar
Yup, it was nothing impressive to say the least. Some of its parts though, like the throttle body unit, work very well on the smaller 305 and 350 TBI motors.
Old Jun 8, 2004 | 01:50 AM
JoeMan's Avatar
Engine: LB9 (305)
how much dose it cost to rebuild a set of heads about?
Old Jun 8, 2004 | 01:54 AM
JoeMan's Avatar
Engine: LB9 (305)
ok im goin to see the motor tomorrow evening probly goin to pick it up the guy says it runs great so i'll keep in touch i'll probly need help since this is my first engine swap
Old Jun 8, 2004 | 01:57 AM
JoeMan's Avatar
Engine: LB9 (305)
im thinkin im goin to put a bigger cam in it as well. oh yeh anyone know how much it will cost to get a new computer chip and could i use the performance chip that is on the old one in the new one or do i have to get a new performance chip too?
Old Jun 8, 2004 | 09:27 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You are going to have to get a new chip. The best way is to burn them yourself which will cost about 300 bucks for all of the stuff. If not, you will have to datalog your car and send the info into a reputable burner www.tbichips.com and have them do it for you. They are only a stab in the dark at best and the only true way to get the right "right" is to do it yourself. I would put that engine aside and work on it while you learn chip burning along with what else makes TBI cars tick. You will want to change the heads and cam right away. The stock ones on that motor are pure garbage.
Old Jun 8, 2004 | 11:26 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Its not all that bad! My friend has headers and alot of other stuff done to his and had 350 hp. 485 fl/lb or torque....He just put a Whipple on it and is pushin over 500 hp....Through the stock throttle body!
Old Jun 8, 2004 | 12:37 PM
JoeMan's Avatar
Engine: LB9 (305)
but im not keeping the tbi on it im converting it to tpi from the 305
Old Jun 8, 2004 | 07:19 PM
SLOWFIVEOH's Avatar
Engine: 355
I know you are, I was just commenting on someones post about 454 TBI.... In your case...Look for a thread I did a while ago about converting a 305 IROC I have to a 350 and using the 305 TPI...
Old Jun 8, 2004 | 07:56 PM
five7kid's Avatar
Shifty missed that, I believe.
Learning to burn your own PROM is time and money well spent.
Old Jun 8, 2004 | 11:23 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Still have I think
Anywho, five7kid is dead on about tuning. It is the lifeblood of TBI cars when you start to mod them.
EDIT: So are you going to TBI or TPI? Sorry, I am not hitting on all 8 tonight.
Old Jun 8, 2004 | 11:42 PM
five7kid's Avatar
He wants to put his 305 TPI on a 350 originally equiped with TBI.
Old Jun 9, 2004 | 02:05 AM
JoeMan's Avatar
Engine: LB9 (305)
ok i have the engine now so what cam should i get? i want somethin with decent power all the way through the revs
Old Jun 9, 2004 | 02:30 AM
JoeMan's Avatar
Engine: LB9 (305)
hi will i also have to change my injectors? and if so how much do they cost about
Old Jun 9, 2004 | 07:34 AM
five7kid's Avatar
The questions you're getting into now are better answered on the TPI forum (injectors) and PROM forum.
Old Jun 9, 2004 | 08:22 AM
SLOWFIVEOH's Avatar
Engine: 355
Decent power throughout all the rev range is gonna be difficult with a stock 305 TPI setup, Thats why I just stayed carb when I swapping my motor from my 82' in the IROC next month.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
