opinions on emissions
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
I want to swap my 305TBI for a GMPP 350 crate motor with a carb. Can I pass an emissions test (they don't do a visual test but they do put it on a dyno and take it up to 35 mph) My car barely passes emissions tests as it is. I figure a new motor, even if it is carbed, should run better/cleaner than my old 305. I just wanted some opinions. Thanks.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: opinions on emissions
Engine: 5.7, 5.0
Re: Re: opinions on emissions
Originally posted by ShiftyCapone
You can still pass with carb if it is dialed in right and you use a cat.
Car: '90 RS
Engine: 377 LSX
Re: Re: Re: opinions on emissions
Can a cat function properly without the use of the air pump?
Engine: 5.7, 5.0
Re: Re: Re: Re: opinions on emissions
You can get a cat without AIR. That is the route I would go. Cat free is the only way to go carb.
Use the cat, but get one without AIR. Also get a 3 way cat if you're gonna get one. It has the catalyst rhodium in it as well, which functions to reduce NOx as well.
Car: '90 RS
Engine: 377 LSX
Re: Re: Re: Re: Re: opinions on emissions
So do you recomend a cat or not? You post is a little confusing. But thanks for the reply
Eastern converters makes one. I know for sure they have 2.5" and 3", not sure about other sizes. I bought 2 of the 2.5", but unfortunately didn't have room for em.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
