305 heads on a 350 block
Old Jul 13, 2004 | 05:06 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i currently own a 305 tpi firebird formula. i believe the engine is gonna go soon, so i'm planning to swap in a 350. i've heard 305 heads on a 350 short block can get very nice power if paired with a nice cam. i want to save money seeing i dont want to spend more than 1000 dollars on the engine. i know a guy who makes short blocks for like 500 bucks. anyone know what cam to pair with my 305 heads?? also i'm planning to swap the tpi over on the 350 as well, changing the injectors and possibly the lower manifold too. sorry if this question is asked a lot, but i would appreciate some help thanks
Old Jul 13, 2004 | 05:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They will work. Try a searchring because this comes up an awful lot.
Old Jul 13, 2004 | 05:37 PM
bigchief's Avatar
arg not findin anything for some reason keeps sayin page not displaying or whatever
Old Jul 15, 2004 | 10:45 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Have you tried searching "305 heads" in the General Engine Tech forum ?
Old Jul 15, 2004 | 10:57 AM
Drakar's Avatar
Here is a quick answer from everything I have seen searching.
305 heads will raise your compression
If the 350 heads are swirl port (TBI Trucks) or they are 882's then the 305 heads if 416 or 081 will be a big improvement, most say to cut for 1.94in and if there is room 1.60ex with a good port and polish the heads should support good numbers. Sittingbull and others have had good ported flow numbers from worked over 305 heads.
Old Jul 15, 2004 | 05:03 PM
bigchief's Avatar
alright man, ill try to just find out which heads they are exactly and then match up a good cam. thanks
Old Jul 15, 2004 | 08:34 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
yeah i had that setup on my iroc. the 305 heads give you like 10.5-11:1 compression with flattop pistons. if you work them right and open up the valves you will be really happy.
ever been sideways in 3rd gear?
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
