block numbers and swap legality?
Old Jul 18, 2004 | 11:36 PM
3liter914-6's Avatar
I did a search and found that at least in CA the referee station determines swap elegibility by the casting number on the block. That is, if you have a '90 Camaro with a '70s 4-bolt they'd look at the casting # and fail you.
Is there any way for them to narrow down the year other than the casting number? I'm asking because I want to stick an '87 L98 engine in my 1990 car. I could track down all the proper emissions stuff, but I don't want to rebuild a motor and then get screwed over the matter of 3 years on a shortblock that's identical. Theoretically they should be indistinguishable since they'd have the same casting number, right?
Thanks for any help!
Old Jul 19, 2004 | 10:04 AM
Drakar's Avatar
Mortec.com
That will give you the year range of that perticular casting number. Some 350 1-piece run 87-89 others 87-90+ check it out and see.
1984HO
Mar 19, 2021 11:59 AM
onefreakz
May 14, 2018 12:15 PM
theshackle
Mar 5, 2017 06:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
