Any way to do this???
Old Jul 20, 2004 | 11:02 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
I have a 92 RS 305 TBI and i went to a Carbed 350 and got it running but the timing is all f***ed up.........i'm pretty sure i need a new distributer but was wondering what kind and what kind of coil....Also is their any way at all to use the stock distributer like unplug the computer from the distributor??...any help would be greatly appreciated.
Thanks,
25thredrs
Old Jul 20, 2004 | 11:18 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
Hello
you either have to hook up the compuuter to the distributor or go to a vacume advanceor mechinal advance distributor. with the computer disconected from the distributor there is no way to advancce the distributor.
later and GB
RK
Old Jul 20, 2004 | 11:38 PM
Drakar's Avatar
grab a new MSD unit if you have the cash or just grab a any NEW, don't bother with a rebuilder, they cost almost the same.
anyways my brand choice is MSD and ya you need one for vaccum advance
Old Jul 20, 2004 | 11:42 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
nothing wrong with going to the junkyard and picking up a good used distributor and rebuilding it ...how much does a msd distributor cost ...i know you can rebuild a used one for around 75 bucks i doubt you can buy a new one for that and the rebuilt one will be just as good
Old Jul 21, 2004 | 02:18 AM
Rick King's Avatar
Car: 1987 TA
"nothing wrong with going to the junkyard and picking up a good used distributor and rebuilding it ...how much does a msd distributor cost ...i know you can rebuild a used one for around 75 bucks i doubt you can buy a new one for that and the rebuilt one will be just as good"
Thats what I did and I have only 55 into it with stock parts, coil, cap, and roter where ok I just recurved it with springs and put an adjustible vacume canister on it and modulator
later and
GB
rick
Old Jul 21, 2004 | 07:30 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
I bought an HEI Distributer with vacume advance the other day but the cap was too big to fit in my car......has anyone else ran into this problem?
Old Jul 21, 2004 | 08:52 AM
THEGENERAL's Avatar
later and
GB
rick
yeah alot of people are afraid of rebuilt parts for their cars but in my opinion i think that they are just as good for alot of thing ..of course some things you shouldnt do that with but a distributor is fine in my book just check it out really good and make sure the gear is good and then replace what needs replaced then your ready to run
Old Jul 21, 2004 | 10:00 AM
Rick King's Avatar
Car: 1987 TA
i KNOW THIS IS NOT HOW YOU SHOULD FIT THINGS UNDER THE HOOD, BUT ON THE 68 CAMARO THE GUY THAT OWNED IT BEFORE ME used a Dinnging spoon and hamer to reshape the firewall or in otherwords he dented it pretty good.
Old Jul 21, 2004 | 10:02 AM
THEGENERAL's Avatar
definatly not the right way but definatly effective
Old Jul 21, 2004 | 05:28 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Hell no. All V8 third gens 82-86 had the big cap HEI. The only way the cap or housing don't clear the firewall is if the engine isn't mounted on the right mounts in the right location. The vac. advance could be oriented wrong though.
