Lt-1 wiring questions??
Old Jul 21, 2004 | 10:10 PM
Les's Avatar
Les
I have a 96 lt-1 engine and a few questions-
Manual wiring harness
computer is 16214399 vats deleted-
can the trans wiring be completly removed,am using the turbo 400 in this one.
Wiring pig tail into car has
purple-s on starter
orange-pc power
black whit stripe-grd
red- ????????
Cruise control- two wire terminals-delete
blue-or white pig tail which is the stop light and wich is the clutch switch -can I delete all the clutch or do I need to wire up so the ecm and starter thinks the clutch pedel is pushed down??
Heated o2 into each header or will only one work?
The coil has 3 terms and the plug only has two wires 3rd wire is not present-any problems?
Any answers will be greatly appreciated Thank You- Les
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
