vortec heads
Car: '89 WS6 Trans Am
vortec heads
I'm putting a 350 with vortec heads into my 305 TPI trans am... I know i need a new tpi base plate for the heads at the absolute minimum... I'm wondering if the ac, alternator mounts etc will bolt up to the heads correctly.. the block is from a 1976 1/2 ton if it matters..
thanks
thanks
Car: 1987 TA
Engine: 350 stock/twecked
Hello,
check to see if the heads have the came accesorie bolt holes. if not then you will have to figure some thing else out. There may be a difference in the exaust bolt locations from some rummors I have head but don't know for sure
later and
GB
rick
later and
GB
rick
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A serpentine set-up will bolt to the heads. The exhaust bolt locations are also the same as any other small block Gen I or II. Not sure about the compatability of the lower part of the brackets and that block.
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
I used VORTEC heads on my 383 swap and had absolutely no problems getting things to bolt to them. I also used a late model roller cam block so I did not have any problems there either.
Biggest glitch I had was bolting runners to the VORTEC TPI manifold- I used SLP runners and had to gring them in two locations to get them to clear the vertical intake maniflod bolts. I speculate that large tube runners like ACCEL or ASM and stock runners would not have a problem.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
A Gen. I block is a Gen. I block, for the most part. The bolt patterns are the same. I have a "010" block from a late 70's Blazer and it bolts up the same externally as my '96 "880" Vortec truck block. Both of which bolt up identically as the 305 LG4 block in my Caprice.
thanks for all the input.... sounds like the swap should go pretty smoothly..... one other thing... will I need a new chip for the new 350 / heads etc.. or do u think it'll run fine with the existing one?
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
