bare minimum 350
Old Aug 3, 2004 | 09:31 AM
megaracerx's Avatar
bare minimum 350
i'm looking at gettin a camaro SC with no trans/motor and want to swap a 5spd 350 combo...however i dont have the money for a 350hp crate so does any one know of a bare minimum 350 kit/crate? right now i'm just looking for 215-230 hp....any opinions?
Old Aug 3, 2004 | 10:22 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
go buy a chevy hiperformance magazine and check out the adds in the back of the mag.... there are alot of crate engines with the hp your looking for and decent prices or if you want to look at buying a kit go to http://www.naparts.com/ check them out they have some cheap kits for 350 chevys
Old Aug 3, 2004 | 10:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds taylor made for http://www.sdpc2000.com/cart.asp?act...id=123&pid=110
A bit of advice: Get a car that originally had a V8/manual. Even if it doesn't have the engine/tranny anymore, it'll save major headaches.
Old Aug 3, 2004 | 03:07 PM
megaracerx's Avatar
five7kid....that say up 2 85 models...what makes it that way? what diffrences are there? is it the 2 peice rear seal? because i beleive 86+ have one peice seals (sorry for the amount of ?'s...dont know to much about engine swaps...)
Old Aug 3, 2004 | 03:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Different intake bolt pattern and the internally balanced crank + two piece rear main seal, not to mention the older style valve covers with the cork seals. No biggie but they dont seal as well as the newer stuff. After I put mine in the valve covers leaked after a week and the RMS dribbles a little bit. Youll have to use an old style intake and drill & tap a hole in the pass. head if your using a serp. belt. Its also weak. I put a slightly better cam which made it feel alot better. Gives the illusion that its fast since it has alot of torque. If you can, get a better engine to start with. If you dont mind used you could get a vortec or an L98 with relatively low miles. The goodwrench will be a letdown since it doesnt make much power with the crappy heads and cam.
EDIT: youll need an older style intake, flywheel, and a balancer with the timing mark off to the side to use this motor. You can use a newer one but youll need another timing chain cover with the timing pointer in the center. I think you may have to since the timing pointer thats off to the side is blocked from view with a v-belt system. Theyre commonly available parts.
Re-EDIT: Server chopped off part of the post
Old Aug 3, 2004 | 03:28 PM
megaracerx's Avatar
but everything will fit in say...and 86 firbird? just cant use my old stuff? and about power....i have a stock LG4 in a trans am...not my idea of "fast" but i'd like to start building a "race" car...just for weekend outing and so forth..but like i said...i dont have a 5k budget...so...a used might be a good idea
Old Aug 3, 2004 | 04:00 PM
five7kid's Avatar
The only thing that would have to be changed to get that engine in an '86 would be the flexplate (flywheel if manual).
If you want to build a "race" car, that Goodwrench 350 isn't the right place to start. Period. It's doing fine in my fullsize '84 van that we use to tow the horse trailer, however.
If you want an LG4 to go faster, you need to fix the air cleaner, exhaust (all of it), cam, and heads - in that order. The Goodwrench 350 addresses none of those areas - it just adds 45 more cubic inches that try to breathe through those restrictions.
Old Aug 3, 2004 | 08:21 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
hello
if you look around you can find corvet motors and trannies with the computer for about that price. if needed let me know and I can check the local area in MN for you as I am going to the yards on thurseday. my e-mail
sirekings@yahoo.com
later
Old Aug 4, 2004 | 10:11 AM
megaracerx's Avatar
thanks for all the info guys..how much (logically)will i end up spending getting an LG4 to about 220-240 hp? more then say...2500? because if it is then i could get the 350 which starts off with 250 with no modds for $13-1800. sorry for being dumb guys but i'm new 2 the idea of engines swaps, i just really started looking into it because i'll gain access to a garage within the next year and i'll finaly have a place 2 lower and really make some decent power...alot better then the gravel drivway i have now!
Old Aug 4, 2004 | 10:40 AM
five7kid's Avatar
Assuming emissions-legal is required:
Exhaust: Hooker 2055 headers, ~$375 (add about $150 for coated). Catco direct-fit TPI single cat, $120. Cat-back, $250-$500.
Air cleaner: Dual snorkel w/scoops & hoses, ~$150-$200 (used, TGO classifieds or ebay).
Cam: Crane Compucam, lifters, timing set, ~$200.
Heads: Ported, 1.94" intake valves, springs to match the cam, screw-in rocker studs, guides cut for positive stem seals, ~$500-$800, depending upon how much you do yourself and how much work the heads need (guides, for instance).
That'll get you in the 275-300 gross flywheel HP range easy in a 305. My combo computes to about 250 RWHP. If you get a 350, of the above you'll need to do the exhaust, air cleaner, cam, and heads (you see what I'm getting at here?). If your 305 needs bottom end work (rings, bearings, pistons, etc.), don't bother - get a 350 core and work it over. Same parts (assuming decent heads, not 76cc chamber smogger 882 castings, for instance) will yield 350-375 GFHP.
You also have to figure on upgrades to the rest of the car: Subframe connectors, higher stall torque converter if auto, etc.
Old Aug 4, 2004 | 11:42 AM
megaracerx's Avatar
alright, what are the stock head CC's? i found a set of 58cc's on ebay for a reasonable price..but is there just stock then it doesnt matter...all that works 2 about 1800 (i have the hooker compitition cat back already...so...now its a matter of finding parts
Old Aug 4, 2004 | 11:54 AM
five7kid's Avatar
Stock 305 heads are 58cc. It would be good to get the casting #'s, though, because you don't want LO3 TBI swirlport 305 heads.
Old Aug 4, 2004 | 11:56 AM
megaracerx's Avatar
so what cc should i look for? or should i have mine reworked?
Old Aug 4, 2004 | 12:00 PM
five7kid's Avatar
58cc.
Working over your existing would be fine. They're good heads to work with.
Old Aug 4, 2004 | 12:02 PM
megaracerx's Avatar
ok....ne question a stock 700r4 will still be fine? and what about my 3.08's out back? (i know there not the best) but they should handle the gain in power
edit: i didnt know you were a mod, thank for taking time out of your mod duties to help a newb
Old Aug 4, 2004 | 12:18 PM
Projek: 85 3800's Avatar
Car: 85 Firebird
Engine: 3800 Series II
still looking for an engine kit? spend $5.95 and get the P.A.W. 1200 pg catalog So much engine stuff in it, that it'll make you puke. A shesh load of engine kits for you in there.
Old Aug 4, 2004 | 12:58 PM
megaracerx's Avatar
that is a big help Projek! thanks dude
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Billy Decker
Sep 4, 2015 03:46 PM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
