Droping TPI 305 into '77 firebird
Car: Bitchin' 92 RS
Ok, I have the engine, The wiring harness is shot and I have none of the computer equipment, what will be needed? I can supply more info if needed.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
And some 3rd gen related information before they close this thread
Car: 1986 Trans Am
Street and Performance will have retrofit wiring harnesses for TPI. They will have everything you will need and they can walk you through it.
They are on the net.
Car: Bitchin' 92 RS
from what I've read, it looks like all I need is a wiring Harness and VATS module, along with the apropriate fuel tank, lines, and pump.
is this correct?
thanks
is this correct?
thanks
Transmission: 4L80E/4L80E
It's almost the same as putting a TPI system into an earlier non-TPI 3rd gen.
Painless also makes a retrofit harness. The rest of the details depend upon the details of the TPI you have.
The intent is to keep discussions 3rd gen related. If that is possible, the thread can live. Otherwise...
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
