350 with 4 bolt main or 2 bolt ? what's better ?
Old Sep 10, 2004 | 02:12 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Im about to do a swap ...and i have a doubt
this guy tells me the 4 bolt main its better than the 2 bolt
why ????
its a 1975 350
Old Sep 10, 2004 | 02:23 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
the 4 bolt will hold more hp and higher revs if built correctly
but the 2 bolt can be made stronger if you spend the little money and have splayed 4 bolt caps installed
Old Sep 10, 2004 | 08:07 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
The two bolt is fine for the street.
If your going racing and running over 6000 rpm all the time then ya want a 4 bolt.
I think a two bolt should be good for 500hp if your machining is all good
But then hey 4bolts can be had for the same price as a two bolt.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
