V6 to V8swap, fuel pump??
Old Sep 15, 2004 | 01:18 PM
355Bird's Avatar
Car: 87 Firebird
Engine: 355
Transmission: 5 spd
okay so i went over the briefing at the top of the forum about v6 to v8 swaps. I just dont understand what you would have to do for the fuel pump. If my 87 bird has an in-tank fuel pump all i need is a 3-port regulator with a return, and then what would the oil pressure safety switch do? And i allready bought a holley "red" pump so how would i use that and bypass the in-tank pump without taking it out. Basically if anyone can explain, in a little detail, how to run fuel to my 350 in my situation.
thanks
Old Sep 15, 2004 | 05:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The V6 uses an oil pressure switch. You need to use it on the V8, too, that's all.
I'm not sure of the details about getting the power to the pump on your particular application. Some used the ECM, others didn't.
You can't avoid taking out the in-tank pump if you don't use it.
Old Sep 15, 2004 | 10:29 PM
NoUseAbleNames's Avatar
when mine was carbed i used a 3 port return and used the oil switch off the v6 and kept my ecm in it.
Old Sep 15, 2004 | 10:57 PM
ljnowell's Avatar
That is the route most people go with. When I did the v6>v8 swap, i just dropped the tank, modified the pickup and installed a mechanical pump on the block. It was a lot cheaper, and works just as well, if not better because it is a lot simpler. Whatever you do, dont try to leave the in tank pump in if you arent going to use it. It will cause problems.
Old Sep 16, 2004 | 02:39 PM
355Bird's Avatar
Car: 87 Firebird
Engine: 355
Transmission: 5 spd
so can anyone walk me through how to keep the in-tank pump to fuel my motor. all i can gather is to use the original fuel lines and attach a 3 port regulator w/ bypass before the fuel filter and followed by the carb? really hazy on this topic so anything will help.
Old Sep 16, 2004 | 04:17 PM
ljnowell's Avatar
Didnt do it on mine, but to my understanding, you must retain the factory oil pressure shut off switch, or at least you should. I guess you could toggle 12 volts to it, but it wouldnt be a good idea. As far as physically installing the regulator, line from the tank goes to the in port, the return line hooks to the return port on the regulator and the fuel line to the carb hooks to the out port on the regulator.
Old Sep 16, 2004 | 07:46 PM
yupyup's Avatar
When i did mine I left everything the same as before the swap,. I hooked the ops wires to the v8 ops and hooked up the mallory. Its been working fine for over 4k now.
Old Sep 16, 2004 | 07:55 PM
ljnowell's Avatar
new user name, or a new user altogether?
Old Sep 17, 2004 | 08:29 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
wow that guy didnt last long at all 3 posts...LOL
Old Sep 17, 2004 | 11:34 AM
ljnowell's Avatar
What the hell? I wonder what was up with that? Anyone here know? c'mon Five7, I know you do!
Old Sep 17, 2004 | 11:35 AM
THEGENERAL's Avatar
he must have pissed in someones wheaties .....
Old Sep 17, 2004 | 12:57 PM
shouda changed his proxy before using a new name...lol
Old Sep 17, 2004 | 01:17 PM
ljnowell's Avatar
so who was it anyway?
Old Sep 21, 2004 | 01:44 PM
five7kid's Avatar
Sorry, been unavailable for a few days.
The best way to describe his other two posts is, "Does not play well with others."
Old Sep 24, 2004 | 04:46 PM
inohcent's Avatar
yeah that does help doesnt it.
Old Sep 24, 2004 | 05:04 PM
ljnowell's Avatar
This is almost like a game, I like it!
Old Sep 24, 2004 | 05:26 PM
THEGENERAL's Avatar
wow that last one was all of 2 posts man five7 your getting quick on the draw now arent ya ...LMAO
plink another one gone.....
Old Sep 25, 2004 | 09:58 PM
five7kid's Avatar
Somebody else. I only heard about it after the fact (I was out of pocket at the time).
Old Sep 25, 2004 | 10:00 PM
THEGENERAL's Avatar
lol....they dont last long around here any more do they ...LOL
Old Sep 25, 2004 | 10:03 PM
ljnowell's Avatar
No they certainly dont, we better keep counting our blessings general!
Old Sep 25, 2004 | 10:11 PM
THEGENERAL's Avatar
what kinda beer you like five7.....LOL
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
