73 Firebird Esprit Swap
Old Sep 19, 2004 | 03:33 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
I got a killer deal on a slightly modded engine out of my friends 73 firebird. Its just the 350, no tranny or anything.
out of that car. I have a 2.8 V6 with a T5. What options do I have for the transmission? Doesnt the Pontiac engine have a diffrent bolt pattern? Also, Can I stick an automatic in there temporarily until I get my other engine and the 6 speed I plan on getting?
thanks
Old Sep 19, 2004 | 09:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you;ll need to combine the Poncho 455 sticky w/the V6-->V8 swap sticky.
And for auto options, & manual, you need to get the B-O-P bellhousing/bolt pattern ones.
Old Sep 19, 2004 | 09:34 PM
Car: 95 Z28
im confused
BOP is buick olds pontiac right?
what about stickin a munchie 4 speed in there?
Old Sep 19, 2004 | 09:38 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
you will need the buick , olds, pontiac bolt pattern transmission and then your going to have to do something with your torque arm and engine mounts youll need different headers which you can buy ..it can be done its just alot more involved than a chevy 350 swap is in these cars
Old Sep 19, 2004 | 09:40 PM
Car: 95 Z28
cant I just use the manifolds on the engine now?
Old Sep 19, 2004 | 09:42 PM
THEGENERAL's Avatar
do you mean the manifolds on the pontiac 350 your getting ?
it depends on how they angle out and i seriously doubt your going to find an y pipe for them that will fit in your car youll need headers to make it work .....
Old Sep 19, 2004 | 09:43 PM
ljnowell's Avatar
You could do that, and have a custom Y pipe made. You will need the proper mounts. And of course, everything will be kinda backwards. You will need a trans with a BOP pattern, or an adapter plate. I have seen them in summit, I dont know what they run though, seems like it was under 50 bucks.
Car: 95 Z28
damnit. ill probally have to pass on it then. but a 350 thats slightly modded, complete engine for 300 is a good deal :'(
Old Sep 19, 2004 | 09:45 PM
THEGENERAL's Avatar
not necessarily if you search about it there are alot of people out there that have put these in their cars do a search and you will see.
Old Sep 19, 2004 | 09:46 PM
Engine: 5.7 / 7.4
why give up so easily????
Old Sep 19, 2004 | 09:47 PM
Car: 95 Z28
cause im in college and broke as a joke
Old Sep 19, 2004 | 09:55 PM
THEGENERAL's Avatar
if your broke then dont even attempt it a v-8 swap alone will cost you enough but to go to a pontiac engine too your not gonna have the funds to do this project .....
Car: 95 Z28
im gettin a job at a pontiac dealer in the body shop probally but I still cant really afford much. I'll probally just get a loan and get a 4th gen...
xkingcodex
Feb 12, 2020 07:43 PM
masonta
Aug 31, 2015 10:14 PM
E Rod
Aug 28, 2015 05:17 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
armybyrd
Aug 10, 2015 09:23 PM
