Going to a Swap Meet this Weekend
Old Sep 20, 2004 | 08:09 AM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
I am going to a swap meet this weekend and I am lookingto pick up a block or engine to start my carb buildup. IS there anything I should be looking for when trying to find a goodblock? Also What casting numbers should I look for?Thanks
Old Sep 20, 2004 | 10:59 AM
ede's Avatar
ede
1 piece rear seal, 4" bore
Old Sep 20, 2004 | 04:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
... or 2pc seal, 4.125" bore
Old Sep 22, 2004 | 01:45 PM
Car: 1988 T/A WS6
I asked this on the carb board, but they told me to ask here...I am planning on using this block for a carb buildup making about 375hp at the flywheel. This car is going to mainly be a weekend warrior with maybeabout 5 trips to the track a season. Would it be beneficial to my setup to go with a roller block? Thanks
Old Sep 22, 2004 | 01:51 PM
Air_Adam's Avatar
The block itself won't make much difference, but the fact that you can use a roller cam is a good thing. Roller cams have more power potential than a flat tappet cam, because the rollers can handle more radical lobe profiles.
Basically, a roller block is a good find, but theres nothing wrong with using a regular flat tappet block. You just can't use the same wild profiles that you can with a roller setup.
BADNBLK
Nov 16, 2016 09:12 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
gwade12
Aug 8, 2015 08:17 AM
